Page 345 of 549 FirstFirst ... 245295335340341342343344345346347348349350355395445 ... LastLast
Results 5,161 to 5,175 of 8222
  1. #5161
    Feb 2013
    want to exchange VVDI to VVDI2 (planning to do that for long time), but I was asked to send unit only by slow shipment to china and will get unit by slow shipment. I can't work without tool for 2 months (at this time of year maybe even longer).
    Now there is distributors in Europe, can I sort out VVDI exchange with any European distributor ( I can pay all shipment costs and exchange fee)?
    Contacted one of Europe distributors, but he is not providing this service.
    Maybe there is a list of European distributors?
  2. #5162
    Top Poster mexjack's Avatar
    Philippines
    Which is vvdi 1??
    Enviado desde mi SM-G935F mediante Tapatalk
  3. #5163
    Nov 2018
    I also need it
  4. #5164
    Does VVDI2 support add key by dump for 2012 Jaguar XF with KVM 0L01Y ?
  5. #5165
    In EEP
    Quote Originally Posted by kvadratas View Post
    Hi your problem solved DHL 3 days to china and 2days to europe
  6. #5166
    May 2013
    Default VW Amarok 2011 Pin Code and CS?
    Hi everyone, 2011 VW Amarok, read 24c64 but VVDI2 doesn't recognise it so didn't put it in to service mode. Any advice on how to get the pin and CS from this cluster? Tried as well with all keys lost but it says security access failed. Thanks for any help!
  7. #5167
    jodge's Avatar
    Mar 2017
    Quote Originally Posted by Carkeysa View Post
    did you tried from ECU?
  8. #5168
    May 2013
    Yes it says security login fail.
    Quote Originally Posted by jodge View Post
  9. #5169
    Maartinj's Avatar
    Nov 2010
    what is not recognize ?
    service mode with 24c64 is all this same
    if Autodetect not work, select proper cluster with service mode and must go
    if not , send LOG to tech support, make it proper way please
  10. The Following User Says Thank You to Maartinj For This Useful Post:
    Carkeysa (20th November, 2018)
  11. #5170
    Feb 2013
    VVDIshop says only slow shipment
    Probably they afraid of customs.
    Quote Originally Posted by vasa View Post
  12. #5171
    Feb 2014
    I have a situation:
    Error - Device clock negative response!
    Could you confirm it is only possible to fix by sending to the factory?
  13. #5172
    Apr 2016
    I tried to read bcm2 audi a5 2015 but error
    I want to add a second key
    was someone trying to read bcm2 from bdm on the table??
  14. #5173
    jodge's Avatar
    Mar 2017
    Quote Originally Posted by kluczbum View Post
    did you removed the 0 ohm shortcut?
  15. #5174
    Sep 2016
    Its because 2015 Audi A5 is most likely crypted BCM. No solution for this BCM yet.
  16. #5175
    Oct 2015
    Soviet Union - USSR
    Hello dear members!
    Audi A4 2004 Rb4 2001+
    Add key sucsesfully, but on dash i see DEF car is start ok. 4-3 i fix by button ( repair No start by VVDI2. but need fix DEF only. Who how fix that?
    I cant see any button on VVDI2 ( repair DEF , like avdi )
