autoTkey (21st November, 2018), Fernandowap (23rd November, 2018), ghostrider72 (20th November, 2018), p1et (20th November, 2018)
It's unbelivable Why did you choose the Dallas?? What if you choose wrong backup battery supplier there will be plenty of mad customer It's a bad joke when you have customers all around the globe Smartcards framework? Like JCD?
@everyone else
It's a good security in-chip system called Dallas. The chip is working until it's supply voltage is present. When it's interrupted even in short time the Dallas is erased and after the backup battery exchange you have to reupload the security data to the Dallas again. Obviously for security reasons they will be keeping this data safe. So no chance to online reupload. Thats the reason why do you have to send back to china.
Hi everyone, i am trying to program a key, 1998 mbz ml, ,w163, aam, with the pcf7935. My vvdi prog wont do it and gives me an error message. I will post the picture. I have tried 2 different chips, same error pops op. The tool can identify the transponder but it will give me an error.
Audi Q7 2011 key generated by J518 EZS dump, remote works, or need write glass 8E, then read by obd with working key and write remote then?
Is it possible to reset fem km IN CAR? Is ilevel coverage good/big/any good? If it needs to be on bench do i need working key?
No need for a key, can be done only on bench.
Passat B8 2015. Dashboard 3G0920751 VDDMQBAB SW 4311 Keyless key 3G0959752.
VVDI2 should make spare key without any problems ??
Rgs.
amigokola (24th November, 2018)
Is it possible to do gmc 46E transponder (b119pt) with vvdi2 ? I am not sure if Tango can do it. Only options is camaro 2015 + but showing 24c32 instead of 95320 for bcm..
Hi Maartinj,
please could you tell us where can we buy a good quality ID48 transponder?
Thanks in advance...
regards
thanks for your reply Rob,
I have done it in the past reading the dump and program it via obd but I was wondering if the new b119pt (new version of a circle plus if I am correct ) can be program via vvdi2 too.
BCM part number is 13510531.
hello
BMW FEM USA 433 Mhz key programming is not working
key added but key still in unlock state -> remote not working just start if i put key near to steering column key mark
and this was happened to me when i try to add key to an e60 with key-less go function,
with the latest version of sw i think was VVDI2-InstallerV560 key programming was not ok (remote and key-less go function not working but car start if i inset key in slot)
and with VVDI2-InstallerV550 key programming was ok remote and key-less go function working
and this is for sure because i try 2 times but now i cannot use older version because of firmware !!!!
castin (27th November, 2018), HeXeN (27th November, 2018), PierreTheron (9th April, 2019), rob h (27th November, 2018)
