That's not what you should look for. You need the same MHZ for it to work. Also if it's Keyless Go you must program Keyless Go.
There are also very convenient PN numbers on most of the VAG spare parts. If they match it should all be OK. If not OK - return to seller.
hello i replace the FEM in a X1 F46 manual gearbox after i adapted keys and reset fem to start car started 3 times after ELV get locked and do not unlock anymore
because otherwise car do not start, red ISN from ecu and perform BDC replace after i adapt key's and perform ignition off and on ELV wold do nothing
after i do reset fem to start i switch ignition off elv do not lock -> ignition on and car start i perform diag erase all errors and all ok
ignition off and elev locked after this no more joy
put the pointer above "reset fem to start" and there will be help
EDIT
sorry for the miss-leading info just push the button you wish and info/help will be displayed -> read it -> and decide you want to do it or not
keysmith (12th April, 2019)
Will the "emergency switch on" wake up the DME to read the ISN for all keys lost?
After change new module, it is requires reset to make it work, this is what i have to do after second hand BDC was adapted to car (add key vin, ISN change), till i do not perform the "reset FEM to start" car just switch ignition on but no cranking without any error on diag or on display
is for to be able to flash when all key lost, to read isn for DDE need to be read in boot mode, you can check in ECU/CAS ISN what ecu can be read on OBD
sniegavirs (13th April, 2019)
With reset of FEM this is here.
hi all, looking to buy VVDI 2 and just wondering on a couple of Questions, -
1, can it do AKL via OBD on cars like VW Transporter T5, 2011 for example
2. can it do AKL via OBD on Audi TT 2011 for example?
thanks in advance!!
