Page 548 of 549 FirstFirst ... 48448498538543544545546547548549 LastLast
Results 8,206 to 8,220 of 8222
  1. #8206
    wembleyhill's Avatar
    Feb 2009
    hi all found a work around for adapters vvdiprog frequency failed
    supply 3.3v to FMLDO on adapter and all good read and write No problemMQB Adapter.jpg
    use buttons
  2. The Following 12 Users Say Thank You to wembleyhill For This Useful Post:
    autoTkey (29th March, 2024), dule14786 (10th April, 2024), electromech (29th March, 2024), Fallen (29th March, 2024), Faraday (26th April, 2024), jokir (27th March, 2024), norbisko (10th April, 2024), p1et (29th March, 2024), RG550 (3rd April, 2024), Spiritech (9th April, 2024), tepSIJA (30th March, 2024), u.s (1st April, 2024)
  3. #8207
    Sep 2023
    wales/uk
    Hello, looking for opinions on this tool working with programming keys to cas4+ and fem/bdc? Is this worth the investment if you was going to have it sent to you and program the keys on bench.
    also is it good with vvdiprog and vvdi2 for mileage correction in the cluster and fem/bdc?
  4. #8208
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by neilp1990 View Post
    Yes it's working ok plenty of videos on YouTube shows how to do it but also better to have cgpro for some dash
  5. The Following User Says Thank You to teerak2uk For This Useful Post:
    neilp1990 (29th March, 2024)
  6. #8209
    Aug 2015
    is the 3532 adapter working fine as i saw on 3532 VDO are 2 different pcb from VAG
  7. #8210
    Jun 2017
    US
    What could the rover change key id button be usefull for in the program transponder by kvm dump menu? Tried to change the ID of an XM38 Rover key to the one im508 cloned over obd, but obviously didn't work. Was just a test, maybe if I actually locked the transponder? Ended up cloning and existing slot to xm38 via dump.
  8. #8211
    Sep 2021
    NA
    Quote Originally Posted by wembleyhill View Post
    We had to send one of the two progs we have for repair for 3.3v line issue, those and also the BCM2 adapters did not function on one and did on the other... Did not see this to try.
  9. #8212
    Sep 2023
    wales/uk
    finally got vvdi2, what isit like with fem milage correction on the f20? also is godiag adaptors any good with vvdi2
  10. #8213
    Jul 2019
    Melbourne, Australia
    Now I just need to figure out how to make this workaround work with my key tool plus.
  11. #8214
    Sep 2021
    NA
    Quote Originally Posted by Spiritech View Post
    The KTP does not work with the wide connector (the red on the picture), but does with the narrow one that ships with KTP itself
  12. #8215
    Sep 2023
    wales/uk
    Hello, has anyone used this on an 2013 audi s3 facelift all keys lost?
  13. #8216
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    ===== VAG V7.3.6 =====
    1. Support MLB immombilizer key learning-Require VVDI-MLB TOOL
    2. Support Fix dashboard data for MQB48-NEC35xx(Lock) type
    3. Support Clone MQB48-NEC35xx(Lock) type dashborad(Copy CS/Component protection data from old data to new data)
    4. Support Fix KM for MQB48-RH850 type-Require MultiPROG or KEYTOOL PLUS
    5. Bugfix
    http://dl.xhorse.net.cn/product/vvdi...tallerV736.exe
  14. The Following User Says Thank You to teerak2uk For This Useful Post:
    neilp1990 (12th April, 2024)
  15. #8217
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Anyone know procedure to swap cluster in VW Tiguan 2014
  16. #8218
    Sep 2023
    wales/uk
    Anyone used vvdi2 for mileage correction on a fem module from an 120d f series
  17. #8219
    yes, can be done
  18. #8220
    Sep 2023
    wales/uk
    Hello, I have gone to remove eeprom from fem module and it will not come off, won't read by clip neither I'm on step 2 of programming fem/bdc on vvdi2, it warns me not to exit what can I do as I'm unable to remove eeprom. Also what can I do if eeprom has failed?
    Thankyou
    I restored coding all fine, I just can't get eeprom off pcb never experienced anything so tough as one on a fem board from a f20.
