Page 218 of 549 FirstFirst ... 118168208213214215216217218219220221222223228268318 ... LastLast
Results 3,256 to 3,270 of 8222
  1. #3256
    Nov 2015
    Quote Originally Posted by Faraday View Post
    Passat have immo in CCM not dash
    Sorry for that! My bad! I got distracted. Thank you!!!
  2. #3257
    Dec 2009
    Quote Originally Posted by BRMTDI View Post
    Also tried to make dealer key, used same ID48 as one already made in the file, so the car has two keys that work, made dealer key "using already good working position info"
    Still no good, will write chip and lock, chip, will not start with that Glass Chip, will not learn it either.
    Also same tried to learn VIA file, also to try something different, always an error.
    Did You use emulator or not? When you use normal transponder you always must wrote something to cluster or adapt. Using emulator you have copy of key.
  3. #3258
    auto techniek's Avatar
    Mar 2017
    Hoi M8
    What about PSA key programming. Is it only for can cars or also non can ?
    No chance to test it.
  4. #3259
    Jan 2013
    today i tread to make remote control for citroen jumpy with xhorse wireless remote control but have error E0-94
  5. #3260
    Sep 2016
    Has anyone found a solution,
    I came across the same chip today! VVDI2 wasn't able to read it but Orange 5 was able to read it.
    NEC 70F3239.
    After reading it with Orange 5 and loading to VVDI 2, VVDI 2 says "module not supported"
    Anyone know how can I make a key for this car?
    Quote Originally Posted by lpf01 View Post
    here it is, thank you!
    Some update:
    Tried as all key lost via OBD ( turn on headlamp, push break pedal, start emergency lights) but no success.
    Owner found the key of the car but still need for a spare key.
    Installed BCM2 back to car, tried to make spare key via obd but still not work, when vvdi start to connect dash goes dead, key stucks in and software says failed to security access. After remove and take back BCM cables everything goes ok again. Tried 3-4 times, same result always.
    Log files for Samic attached too.
  6. #3261
    Nov 2012
    Quote Originally Posted by auto techniek View Post
    Hoi M8
    For peugeot 508 was ok. But on citroen C3 2010 was not reading pin.
    It is only for can cars.
  7. #3262
    rola1971's Avatar
    Jun 2014
    Dublin
    Quote Originally Posted by AutoKeyGuy View Post
    NEC 70F3239.
    may be extra info?
    car,model,year,bcm?
    where file?
  8. #3263
    yugo45's Avatar
    Apr 2010
    One year and not fix this problem!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Some update:
    NEC 70F3239.
  9. The Following User Says Thank You to yugo45 For This Useful Post:
    rola1971 (25th November, 2017)
  10. #3264
    yugo45's Avatar
    Apr 2010
    You can see files in Lpf01 post , he had this problem 1 year ago and they never fix it .
    VVDI prog do not even have this in menu when you go to Immobilizer AUDI BCM.
    Quote Originally Posted by rola1971 View Post
    may be extra info?
    car,model,year,bcm?
    where file?
  11. The Following 2 Users Say Thank You to yugo45 For This Useful Post:
    dorofteius (25th November, 2017), rola1971 (25th November, 2017)
  12. #3265
    Nov 2012
    Like others say. I mean no disrespect.
    Fix the curent problems first. Then go for updates, like MQB and others.
    Would you thrust a tool that has problems with 2008 dash, to do a G7 ?
    No way.
    Can't you clone another tool ?
  13. The Following User Says Thank You to dorofteius For This Useful Post:
    yugo45 (25th November, 2017)
  14. #3266
    lpf01's Avatar
    Oct 2013
    Quote Originally Posted by yugo45 View Post
    Right.
    Shame but after VVDI2 failed FVDI make key in 1 min....
    Countless lockpicking stuff, AVDI Original, Tango, Orange 5, TMpro2, sooo mutch chinese stuffs from FVDI Full through VCDS to Benz key programmers, 3 cats and hopefully still 20 fingers......
  15. The Following User Says Thank You to lpf01 For This Useful Post:
  16. #3267
    LauAlf's Avatar
    Vvdi2 Read obd pin code and cs Siemens ppd1.2 error, not read.
    Zedfull read ok.....
    VVDI2 things left to give to read and not corrected.
    Enviado do meu SM-G935F através de Tapatalk
  17. #3268
    whiskeyman's Avatar
    Dec 2010
    where men are men and women eat their babies
    NEC 70F3239.
    Load dump for us to look
  18. #3269
    Sep 2016
    Default 2007 BCM2 Audi A5 NEC 70F3239
    Yes VVDI Prog did not have this BCM under Immo-> Audi
    I've attached the dump read by Orange 5.
    Car was a 2007 Audi A5,
    BCM2: 8K0 907 289 L
    NEC Processor: 70F3239
  19. The Following User Says Thank You to AutoKeyGuy For This Useful Post:
    yugo45 (26th November, 2017)
  20. #3270
    CarCity's Avatar
    Nov 2016
    Inside my clothes
    Why remove download links from VVDI web site ?
    I surprise those who do not want to use the Thanks and Reputation buttons but ask for the password of the files.
