But will always come out support for MQB?
Does not work, had customer vehicle again today, pre-code ID48 would not learn the vehicle, would not start the vehicle.
Vehicle is 2017 VW
Logged in, Cluster Goes Black, Read IMMO, Save IMMO, Make Dealer Key, Make Normal Key for Glass, Pre Codes ID48, Learn Key, Always fails, on older cars never had a issue, this one does not seem to work, when I do it in the way where it learns the keys 1 by 1, learns proxy never learns glass...ID48
Tried by doing it VIA IMMO File, gives me an error... tried several times.
If anyone has success with 2017 Similar car, please let me know...would love some input.
Maybe try emulator of id48. This way you don't have to write anything to cluster. Maybe writing new data is problem.
Possible add spare ?
Audi a4 b7 2.0 diesel . 2005
Key 8e0 837 220k
Sorry dont understand
What is powe class.
I need add new spare chip for start and remote from used key
Also tried to make dealer key, used same ID48 as one already made in the file, so the car has two keys that work, made dealer key "using already good working position info"
Still no good, will write chip and lock, chip, will not start with that Glass Chip, will not learn it either.
Also same tried to learn VIA file, also to try something different, always an error.
Hi M8
can VVDI2 also do immo 3 key program passat 2002 or do I need some old devices ?
Work perfect in immo 3. I made passat b5 , golf 4 , seat toledo and others.
You put blank transponder and it wil do the job in 2 minutes. Guided, so nothing to worry .
auto techniek (20th November, 2017)
Not precoded. Regular keylearn.
Did anyone ever try to work on NEC+24c64 2013+ TFT color display VW Passat dash with VVDI2? I just tryed to read immo data but it only reads some fields. It logs in succesfully, but reading only partial immo data. Changed km ok!
drugowaz (21st November, 2017), fytfh (21st November, 2017), sniegavirs (21st November, 2017), stefyhgs (21st November, 2017), yugo45 (21st November, 2017)
