Page 312 of 548 FirstFirst ... 212262302307308309310311312313314315316317322362412 ... LastLast
Results 4,666 to 4,680 of 8219
  1. #4666
    lidons's Avatar
    Feb 2011
    Default VVDI2 keytool 93c86 Kessys Touareg, Does Not Work
    *VVDI2 keytool 93c86 Kessys Touareg, Does Not Work, precodes the key incorrectly SK-H SK-L.
    *Tango, unknown versión
    excuse my English, is the best.
  2. #4667
    Dec 2008
    Thanks mate, operator error this time.
    Ended up manually entering the key info into the dump.
  3. #4668
    Faraday's Avatar
    May 2012
    The dark side of the moon
    Can you add instrument cluster 2K0920844C version 002 1222 it is from VW caddy 2009 micronas cdc3xxx dash, auto detect does not work.
  4. #4669
    LauAlf's Avatar
    Hello.
    All immo on.
    Old last vvdi2 working.
    Solution edc16u1 make immo off. Flash to audi version. Immo on. Change CS and PIN. Immo off and flash VW version.
    Quote Originally Posted by yugo45 View Post
    Make sure you do not have Immo Off. If you have Immo Off , it will not read any info and will give error.
    Enviado do meu SM-G935F através do Tapatalk
  5. #4670
    szengen's Avatar
    Jan 2017
    Poland
    checking.......
    fang, Narwalus microcephalus,Spectrum Zx, Atari amiga, Commodore +4
  6. #4671
    szengen's Avatar
    Jan 2017
    Poland
    automatic recognition, only at Sierra's effi
  7. #4672
    szengen's Avatar
    Jan 2017
    Poland
    Quote Originally Posted by u.s View Post
    Unable to make key for 2006 Yaris using VVDI2 Transponder Programmer
    Have read data from 93C56A.
    Select Asia->Toyota->Yaris->2004-93C56, load dump and get 'Unknown version!' error.
    Dump and screenshots attached. (key data and vvdi2 error)
    You are a long way before you, before you become a leczczs.rarprofessional
  8. #4673
    Aug 2015
    Can vvdi2 also do keyless key mqb ?
  9. #4674
    LauAlf's Avatar
    Quote Originally Posted by offsystem View Post
    Yes. Tested.
  10. The Following 6 Users Say Thank You to LauAlf For This Useful Post:
    amigokola (22nd July, 2018), CaioW (23rd July, 2018), offsystem (22nd July, 2018), rob h (22nd July, 2018), rola1971 (23rd July, 2018), sniegavirs (22nd July, 2018)
  11. #4675
    Jan 2016
    Because it is Continental Kessy. You must read it with VVDI PROG and then VVDI2 should recognize dump.
    Quote Originally Posted by lidons View Post
  12. The Following 2 Users Say Thank You to amigokola For This Useful Post:
    lidons (25th July, 2018), rob h (23rd July, 2018)
  13. #4676
    DK Veteran labusas's Avatar
    Nov 2010
    Hi, Audi A4 2011, made smart fob but steering light came on and stays on. Never happened before, is this just enough to clear DTC situation or something wrong?
  14. #4677
    ghostrider72's Avatar
    Jul 2012
    UK
    Clear it or drive it around the block. Should go off on its own.
  15. The Following 2 Users Say Thank You to ghostrider72 For This Useful Post:
    labusas (24th July, 2018), yugo45 (25th July, 2018)
  16. #4678
    Dec 2017
    Hello can somebody explain how to get "power class" from the ECU ?
    Must the power class in the dashboard be the same als in the ECU ?
    The car is vw polo 2010 and i must teach a new cluster in the car.
    Thanx in advance !
  17. #4679
    rob h's Avatar
    May 2011
    You can get the powerclass by obd.
    Type in CS, Mac pin, and the program Will search.
    Pwrclass, you could also find by posting enginecode.
  18. The Following User Says Thank You to rob h For This Useful Post:
    shotaaa (24th July, 2018)
  19. #4680
    Dec 2017
    Quote Originally Posted by rob h View Post
    So read thru obd ecu eeprom and flash..calculate cs pin mac.
    And after wich option choose to read powerclass? or it will show if i calculate ?
