How!!! And for ews?
Enviado desde mi SM-G955F mediante Tapatalk
How!!! And for ews?
1."can't read password from w639,w203 and w202",some eis of them can,some can't,that it is.
2.About manual,a good advice,thank you.taken it into consideration
3.I think you are talking about Cas Plug?please check in 33page of the BMW manual
4.BMW e46,use the HU92R?which option do cut the key?First measure the thickness of the blade,after cutting,measure the left thickness of the blade
thank you for your trust,we try our best to
alex1881 (26th July, 2017)
About 3 one... Checked manual, always do It before ask, I don't like touch the balls for nosense things...
About manual, just contact me and I can help, also for making cables for test in bench too... Also, I can help to translate yo spanish if you want. Contact me.
about the cas plug,just remind to check.because I don't know if you know that or not,please ignore it.do you have log of that cas plug and car connection fail?
Thank you!
LauAlf (21st July, 2017)
amigokola (28th July, 2017), sniegavirs (21st July, 2017), yugo45 (21st July, 2017)
Ok this is not concerning any issue....just wanted to say love xhorse.
I unlocked 8 Used locked BMW comfort access keys, paired them to the car everything works 100% very happy they added this feature.
lalaina74 (21st July, 2017), louis21 (22nd July, 2017), Maartinj (21st July, 2017), sniegavirs (21st July, 2017)
need to solder with adapter to unlock CA keys for bmw?
Yes. But with vvdi prog or vvdi keytool. On keytool there are adapters without soldering.
With vvdi 2 there is no link.
So. Bad topic . Nothing to do with.
yugo45 (22nd July, 2017)
Need help on this and I want to know if vvdi2 can do it.
I have a Seat Leon PCR2.1 1.6tdi with ecu internal fault. I can read PIN CS and MAC from this. I have a spare ECU from scrapyard, but I can't read MAC CS and PIN because I only have the ECU?. Can I exchange ecu and write original PIN MAC and CS without having from spare ecu? If not, what I need to do this?
thank you!!!!
no,if use vvdi2 to match,should know your spare ecu pin and cs
porsche keys european has 433mhz frequency?
cayenne,panamera etc.
