Page 303 of 548 FirstFirst ... 203253293298299300301302303304305306307308313353403 ... LastLast
Results 4,531 to 4,545 of 8219
  1. #4531
    rob h's Avatar
    May 2011
    Quote Originally Posted by lidons View Post
    Key Programmer > MB ALL type > 05x32 > W168 (7935) - Not Found
    Have you tried with 7930.
    Or create id73 ml transponder.
  2. The Following User Says Thank You to rob h For This Useful Post:
    bursuc (24th June, 2018)
  3. #4532
    lidons's Avatar
    Feb 2011
    Quote Originally Posted by rob h View Post
    @rob h I have not tried to do that test, to the next, thanks
    excuse my English, is the best.
  4. #4533
    Feb 2010
    How to create id73 ml transponder with vvdi2? I never managed
    Enviado desde mi SM-N950F mediante Tapatalk
  5. #4534
    Feb 2010
    In EEP
    Quote Originally Posted by hipolitogt View Post
    Hi on PCF7930 not work you need PCF7935 this trasporder emulated original ID73. After preper transporder need learn in car with Xentry etc. diag tool if it can. But VVDI2 have bug on transporder mercedes from dump and i think not work. trying on W168.
  6. The Following 2 Users Say Thank You to vasa For This Useful Post:
    lidons (23rd June, 2018), mickye_dj (25th June, 2018)
  7. #4535
    Oct 2017
    DOes vvdi prog calculate correct nissan 20 pincode from 20 digit BCM code?anyone tested it?
    when i try with diagcode first 4 digit different then the vvdi prog
  8. #4536
    Feb 2010
    Quote Originally Posted by vasa View Post
    I repeat: where you precode a pcf7935 with vvdi2 to learn on ml? NEVER NEVER managed to do that
  9. #4537
    Nov 2012
    I can give Opel algorithms for calculating pin code.
    Like astra H, on anithing except cim with dg128....
    Iff x-horse is willing to take, let's al give algorithm's for calculating .....
    We will have a better tool .
  10. The Following User Says Thank You to dorofteius For This Useful Post:
    ghostrider72 (24th June, 2018)
  11. #4538
    ghostrider72's Avatar
    Jul 2012
    UK
    Maybe they will be interested if they would read messages mate. Atm many people wont get ANY response from Samic and his team. Unless you want to buy something, they wont respond.
  12. #4539
    Feb 2010
    Quote Originally Posted by ghostrider72 View Post
    I know samic personally. He's a great guy trying to make the best. Don't blame them.
  13. The Following User Says Thank You to hipolitogt For This Useful Post:
    habbyb (25th June, 2018)
  14. #4540
    Oct 2017
    Quote Originally Posted by dorofteius View Post
    Samic is on vocation.
    xhorse should accept this to make tool better.
  15. The Following User Says Thank You to Asifmehmmod1 For This Useful Post:
  16. #4541
    Jul 2012
    UK
    Not saying he isn’t good bloke mate. Just lack of response from Xhorse team, apart of #Martin. And i know im not the only one who complains.
    I’ve reported few bugs to Samic, no response since.
  17. #4542
    jodge's Avatar
    Mar 2017
    he will answer. Maybe not too fast
    Sir, are you classified as human? Negative, I am a meat popsicle
  18. #4543
    rob h's Avatar
    May 2011
    In the prepare transponder menu, you will find ml transponder id73 creator.
    Not sure if that will improve the vvdi2 mb keylearning.
    So, i bought tango licence, mb cars, works 100% with dump from obd.
    Here is the dump, of a ml 2003.
    ml das.rar
    I also have had a problem with the w168 keymaker, all masks, using vvdi2 key tool.
    Next week my gambit will arrive, and i will test that on some mb, also i hear it is not good on w168 (all masks)
  19. #4544
    khalilo_de's Avatar
    May 2010
    ml das.rar
    Tested w168 with gambit not working
    Envoyé de mon SM-G950F en utilisant Tapatalk
  20. #4545
    Aug 2016
    Can VVDI2 calibrate mileage on golf5 visteon dash by obd?
