Page 1 of 5 12345 LastLast
Results 1 to 15 of 73
    Jan 2009
    Default Audi A3 2007 micronas CDC3217G
    Dash comes top me dead after mileage correction by dp3
    Can someone repair flash micronas?
    Tnx
    Jan 2009
    Anyone?
    solved
    Andrei2015's Avatar
    Oct 2015
    How did you repaired my friend? I have situation on Audi TTRS
    Stage 1,2,3, DPF+EGR+SCR+FLAPS+TVA+CAT (all off)
    VAG ME7 LC+ALS+NLS+2step, VAG MED9.1 LC+ALS+NLS, EDC17 LC+HARD CUT
    POPS & BANGS (Schubabschaltung, Crackles)
    on allmost every petrol
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    In my immobox...
    Post here eeprom and flash
  5. The Following 3 Users Say Thank You to lupu_sandu For This Useful Post:
    Andrei2015 (5th May, 2016), kost (30th March, 2017), MV auto (6th May, 2016)
    Mar 2016
    South Africa
    Hi I do them audi,s with clone digiprog 3 v4.94
    Read and change km on of the ignition few times then cluster dies. Unplug take out key and restart procedure from beginning. Ign on plug in redo km reads 0km enter new km u want and bam cluster activates again and changes to the new desired km ignition on off as tool says and that's it. I've done plenty of them specially 2007 to 2010 a3audi,s could be 11 as well. Never had one issue doing it that way.
    Andrei2015's Avatar
    Oct 2015
    Solved by m8 Lupu Sandu, own you a big big beer
    Sep 2015
    Hello you can help me please? i am similar situation
    i tried change km audi A3 8P0920931 with fvdi tacho is dead
    thank you in advance
    cdg3217G DEF.rar
    lupu_sandu's Avatar
    In my immobox...
    Flash ok, pass in pm:
  10. The Following 4 Users Say Thank You to lupu_sandu For This Useful Post:
    Aliazadar (25th March, 2018), Drdiag (6th July, 2017), igni (2nd August, 2019), salkapone (13th March, 2017)
  11. #9
    Sep 2015
    Merci merci beaucoup Lupu -sandu !!! thank you very much all work fine !!!!
  12. #10
    Jan 2016
    Lupu Sandu !!! Master of Our disaster 😉
  13. The Following User Says Thank You to amigokola For This Useful Post:
    Andrei2015 (25th May, 2016)
  14. #11
    Jan 2013
    Default Seat leon cupra
    Hi Guys please help i have similar problem with 1p Seat Leon cupra immo data corrupt no vin no keys no cs
  15. #12
    cinici's Avatar
    Jan 2012
    TURKEY/BURSA
    Default hi all
    8P0920932N DASH DEAD FVDİ CLONE HELP PLS THX
  16. #13
    lupu_sandu's Avatar
    In my immobox...
    Flash repaired ok.
    LE: Small correction added to dump.
  17. The Following 5 Users Say Thank You to lupu_sandu For This Useful Post:
    cinici (28th June, 2016), fuktak (29th December, 2019), geeroam (29th June, 2016), powered by (15th April, 2020), smirnoff_rules (28th June, 2016)
  18. #14
    Jan 2013
    Hi Guys, just small update on my problem, some used vagdash to code keys supplied by dealer, dealer could not code keys, vagdash corrupted cluster. started doing all funny things all warning lights started coming on cluster stayed on with ignition off. I dumped cluster with Xprog put into service mode, that gave me obd access to cluster it then put in vin and cluster serial no cs, Coded keys, only have steering angle sensor fault now, and TPMS light.
  19. #15
    cinici's Avatar
    Jan 2012
    TURKEY/BURSA
    work all ok thx lupu_sandu
