hi hello you can turn on a c2 vts Bosch Me 7.4.5?
med7.1.1 have some support?
They use stealed script to make LC and other
i don't recomend try it at own car, that's same solution can be find in web for free.
All brand FileService - Custom - remapping company
POWER>DPF>EGR>KL>SCR>TVA>DTC's>Lambda>NOx>CustomSp ecialization -
| Diesel | Bosch/Siemens SID/Denso/Delphi/Visteon/Phoenix
TrevelXP (28th September, 2019)
Ohh I need it for an me 9 please.
Gesendet von meinem Nexus 5 mit Tapatalk
Put your VAG me7 files here i will do a few.
Kess v2 FW 5.017 full unlimited token - Ktag 7.020 full unlimited token
ALL EDC17/MED17 EEPROM CHECKSUM + VAG IMMO OFF BY EEPROM - NO SAFE
EDC16/17 POPCORN - ME7/7.5 ANTI LAG - LAUNCH ALS/NLS
DPF EGR DTC SCR, Custom Tuning, Damos Translation, FRF / SGO Files
Professional Engine Software Development
morgano (11th December, 2015)
Hi ecutuner
please i need ANTI LAG - LAUNCH ALS/NLS
I tested the script launch.php and launch.exe does not work
here my file Golf R32 ME7.1.1 https://mega.nz/#!1JwT2TDZ!XG3BlFTX-...0QzgXQYAe8pJRU
Thank in advance
Regards
sonique (8th February, 2017)
Auto script puts data in wrong areas, needs made manually. in your archive there is 2 files which one needs it?
baleavin6562 (21st May, 2017), imcumen (12th December, 2015), morgano (12th December, 2015)
Hi ecutuner
Thank you very much
Best Regards
hello guys also put my files c2 vts
with electronic Bosch 7.4.5 me hope someone help me to activatelettura completa funzionante c2 vts 907_167 ktag.rar
wiseman (13th December, 2015)
a2l.rarif you want a file to this ECU A2L
Hi!
Ecutuners please ANTI LAG - LAUNCH ALS/NLS a3 1.8t me7
Hi ecutuner!
can you do it for bmw ?
