Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 48
  1. #31
    Saulius Saulius's Avatar
    Aug 2010
    Herts, UK
    Diagnosticated solved it!
    "It lives! Engine starts and runs. Using old ESCL I added an extra 12V feed to ESCL at pin 10 where CCM power should arrive but doesn't. (disconnected the wire at CCM) Still had steering lock failure message and faults but VCDS accepted security PIN instantly and adaptation channels were available. Pulled old ESCL and fitted new one (the one the dealer says cannot be used because they tried to program it). Entered Security PIN using VCDS and adapted new ESCL. It worked first go and the chassis number appeared in the boxes and ESCL part number changed.
    No celebration because Engine start was still blocked by immo. I decided to pair engine ecu with CCM as if fitting new engine ECU. Again process worked good. Immo MB001 changed from Engine start NO to YES. Logged out, pressed key and engine started and ran. Car had lost all ABS coding and lost all steering values. It had also gained a faulty EPB which I hoped was via the ABS code loss. Re-coded everything and ran all basic settings. EPB insists a caliper is faulty so I guess standing for a month has upset it. EPB works fine but control module complains about voltage/current. One silly thing left. Dash keeps pinging service now. I keep resetting service but message comes back. aaargh!! At least the engine starts and runs. Thanks for helpful suggestions Jack."
    MagicMotorsport FLEX, Kess / K-Tag original, PCM Flash, MMC Flasher, BitBox, 2wd Dynomet Dyno Road, Ori WinOls.
    We offer: Cars, Trucks, Agro, Construction Machines Tuning / DPF / EGR / Flaps / Throttle / Ad Blue / Lambda / DTC, IMMO off. Also EDC17 IMMO off BY EEPROM with no faults on a dash!
  2. The Following 7 Users Say Thank You to Saulius Saulius For This Useful Post:
    cqae (20th February, 2017), damih (30th September, 2016), Diagnosticated (29th September, 2015), gogoli (1st February, 2018), HeXeN (11th October, 2015), scotlock (28th September, 2015), Weasel3 (28th September, 2015)
  3. #32
    Senior Member Diagnosticated's Avatar
    Mar 2011
    Wow! someone else posting my post for me. Thanks to all who helped.
  4. The Following User Says Thank You to Diagnosticated For This Useful Post:
  5. #33
    simaservis1108's Avatar
    Aug 2013
    Serbia,Belgrade
    This solution using old ESL to give ignition and code new one helped me today...
    I was in the same situation as Diagnosticated...
    2 New locks wouldn't code...
    Fortunately it is solved...
  6. The Following User Says Thank You to simaservis1108 For This Useful Post:
    yugo45 (22nd February, 2017)
  7. #34
    yugo45's Avatar
    Also this will work as well, New Steering lock is Virgin and no need to enter Pin, go direct to Ch51 and adopt it with Pin of CCM.
  8. #35
    Aug 2013
    Serbia,Belgrade
    Ch51 is not available until 16-Security access is gained...
    Comfort wouldn't accept correct pin code with new lock...
    Put old lock back,give ignition,enter pin,go to Ch51,unplug old,plug new,press Do It! and done...
  9. The Following 7 Users Say Thank You to simaservis1108 For This Useful Post:
    amigokola (22nd February, 2017), dannyx5321 (10th February, 2019), doctore (23rd February, 2017), Faraday (22nd February, 2017), ninja123 (22nd February, 2017), sazimam11 (11th January, 2019), yugo45 (22nd February, 2017)
  10. #36
    yugo45's Avatar
    SIMA , was that new ESL form Dealer, or used?
  11. #37
    Faraday's Avatar
    May 2012
    The dark side of the moon
    You need new esl from dealer.
  12. #38
    Aug 2013
    Serbia,Belgrade
    Was new,with ELMOS IC,and not Motorola...
  13. The Following User Says Thank You to simaservis1108 For This Useful Post:
    yugo45 (28th February, 2017)
  14. #39
    Jan 2016
    Have the same situation today but I dont have old ELV. I put new ELV and got ignition no problem but IMMO 25 doesnt accept LOGIN from CCM.
    I see in MVB that there is lock time active. As Yougo wrote - after lock time is gone - I go directly to 51 channel to adapt new virgin ELV ??
  15. #40
    Jan 2016
    Looks like without old ELV I cant do nothing
    Wysłane z mojego SM-G950F przy użyciu Tapatalka
  16. #41
    Aug 2013
    Serbia,Belgrade
    Unfortunately............
  17. The Following User Says Thank You to simaservis1108 For This Useful Post:
    amigokola (7th June, 2018)
  18. #42
    Jan 2016
    This procedure (+ on pin10 elv) works even when there is lock time or I must wait ??
  19. #43
    Oct 2014
    Netherlands
    You must always wait until lock time expires otherwise any module will not process/allow any requests.
  20. The Following User Says Thank You to H2Deetoo For This Useful Post:
    amigokola (8th June, 2018)
  21. #44
    Jan 2016
    CCM was the issue in this one. After change to used one ELV adapted no problem.
  22. #45
    i_shot_the_sheriff's Avatar
    Nov 2008
    Have same problem ,,,,
    This passat came with faulty ESCL ,,,, dash opens all lights but steering fault! I put new steering lock from dealer but CCM won't accept pin code no matter what ! Should i give this +12v feed to the pin 10 and try ?? I always have security wait time 80 minutes
