I experience this fault quite often myself (Yellow then red steering wheel symbol plus beep, beep, beep etc. No dash lights, ignition etc. Steering lock ON).
It always happen for me when gearbox is in reverse. I set the gear in neutral and try once more. And everything is OK.
I also read at this forum that the micro switches in the steering lock often fail over time. And when changing these the failure will disappear.
Maybe someone with genuine AVDI can confirm steering lock virgin and reuse.
CCM eeprom is all you need to get PIN and CS. With good tool. Or some help from this forum.
You could solder over to the new CCM. Or I guess just write from old EEPROM to new.
