blade stream /mag 250 help
Results 1 to 4 of 4
    Nov 2008
    Default blade stream /mag 250 help
    i have tried to search on previous posts but not found any asnwers
    can any one help or advice without not sure if im allowed to ask this but how do you actuall get the kodi or xbmc software on this box all information i seen on u tube seen seems to be showing down loading kodi on a pc or laptop
    does the blade need to be connected to laptop via usb cable or is there a way of directly downloading kodi on the iptv box?
    i have tried attaching a usb stick and external hard drive to the blade stream and then through the box downloaded kodi on to external hard drive kodi has dowloaded sussessfully
    but says permanent error when i go in to downloads on the blade stram iptv box
    and help would be appreciated
    digicon's Avatar
    You cannot install Kodi onto the blade stream, basically the blade stream is a re-branded Mag250 and i am afraid they do not support Kodi.
    Spend ?35 on an Amazon firestick which works perfectly well
  3. The Following User Says Thank You to digicon For This Useful Post:
    super jumbe (1st September, 2015)
    Nov 2008
    ok thanks for that so is the blade only good to use if i buy a subscription and where you receive a code to unlock which are being sold on fleebay or is there more you can do to set it up yourself with a bit of knowledge ?
    digicon's Avatar
    We do not discuss any type of illegal subscriptions or anything to do with Payservers on the forum, I am afraid the Blade media is limited to that we cannot discuss and it cannot do anything else
