Page 1 of 5 12345 LastLast
Results 1 to 15 of 72
    soxten's Avatar
    Mar 2013
    Default Continental SIMOS PCR2.1 Clone or Immo Off?
    I have a SIMOS PCR2.1 as I need to Clone or do Immo Off on.
    Magicmotorsport can`t do this yet.
    Any one as havinga a soulution?
    03L906023MR
    5WP42694AA
    Top Poster + andy99's Avatar
    EUROPA
    Magicmotorsport can`t do it?
    Abritus can adapt it
    i think
    Abritus AK400 BDM100 BMW-EXPLORER Beprog+ CLIP CarProg ETL ELM324 FVDI IDS J-Link GALLETTO3 SMOK K-SUITE Lexia3 MERCEDESINSTRUMENT MPPSv16 MVP ORANGE5 StarC4 TANGO UPA XprogM X-TOLL ZedBull
    Immo off possible only with immo emulator but you need known cs+mac from new ecu first. When you own this data then better to adapt it.
  4. The Following User Says Thank You to autofan1965 For This Useful Post:
    Faraday (16th January, 2016)
    soxten's Avatar
    Mar 2013
    Is it possible to read immo data from spare ecu?
    IMMO data only by AVDI
    Adaption only AVDI or dealer
    hello
    i have magicmotrsports very sad to say , at that time this tool not done , i try with many time support mms help desk but not done
    soxten's Avatar
    Mar 2013
    Can fvdi do it?
    Quote Originally Posted by potatodog View Post
    Why you think adaptation only by avdi?
  10. The Following User Says Thank You to autofan1965 For This Useful Post:
    marioprinz (15th December, 2016)
  11. #9
    Quote Originally Posted by autofan1965 View Post
    Why do you think other tool can adapt PCR2.1?
  12. #10
    mislav88's Avatar
    Mar 2011
    dealer can adapt used PCR2.1 but part number has to be the same
  13. #11
    soxten's Avatar
    Mar 2013
    Ok, I mount ECU in customers car end then try on Vw workshop.
    I report if this work to you all.
    thx!
  14. #12
    Nov 2012
    I had the same problem and in dealer they tell me what cant do it... i did it finally with AVDI
    I hope you solve it
  15. #13
    soxten's Avatar
    Mar 2013
    Did you connect ecu on bench and then read code and den divorce it?
  16. #14
    Oct 2011
    You first have to unlock eeprom by dump so you can read/write by obd. Than read pin cs and mac and write it in used one. Works great
    Verstuurd vanaf mijn HUAWEI P7-L10 met Tapatalk
  17. #15
    Jan 2009
    Servicer lost eeprom data
    Can be put other dump and adapted with vcds?
    wbr
