Hello
Is there is anyone who can help me get the code????
تم الإرسال من SM-A510F باستخدام Tapatalk
Hello
PIN Code: 49141
Allowed transponders: Original Iveco TIRIS DST+
Auto Locksmith / Security Professional
ashraf2000 (20th September, 2018), toxcct (14th January, 2022)
Need pin code from vcm Iveco eeprom 25lc640
Help me need pincode iveco from vcm
PIN code: 63237
HI, i need pin code for Iveco stralis 25lc640
Thank you.
hello
i have tried to program the key to the last truck i got its pin here on this forum
but after i baught keys then cant program
found that the engine ecu has different vin from the truck which mean i dont have a good pair of vcm and ecu
so pls give me the pin to this file which i got from another truck which i had vcm and ecu matched
dump attatched
PIN code 47111
[QUOTE=ashraf2000;3432751]hello
dump attatched
what device can programing?............................
thank
Iam trying to program using jaltest
But cant understand what happenned
Programmed 25640 on vcm and 95640 on ecu
Then on diagnostic the vin not changed on both of them and got the same trouble
What happenedz. Cant understand
Hi need pin code from VCM dump 25lc640, nr 4462700030.
Pin code 39756 is 100/100 Correct
you have two choices in the morning: go back to bed and continue dreaming, or you get up to make your dreams come true
