Results 1 to 7 of 7
    toysoft's Avatar
    Nov 2008
    Default SuperSim Japhar DM500HD : OpenPLi 4.0 for Japhar NC3 Sim - SEPTEMBER 2015
    OpenPLi 4.0 for Japhar Sim NC3 DM500HD, with latest IPTV software working at the best, including 700 channels ! Download link below. Enjoy !
    MEGA Link : https://mega.nz/#!xUEg1BIA!WjfnI5Y9d...6CeOl_QgrWJAo0
    By MastaG for Japhar Team
    Thank you !
    toysoft's Avatar
    Nov 2008
    VU : OpenPLi 4.0 with IPTV (More than 800+ IPTV FREE Channels) by MastaG and Japhar Team
    Users running the previous Gstreamer 1.7.0 image, should be able to peform a Software Update!
    Changes since previous release:
    - mx3L's gstreamer revert which fixes mp4 playback from remote locations
    - Spark drivers updated to 20151113
    - Using aio-grab from oe-alliance which includes fixes for sprak receivers
    - New Japhar IPTV List (thanks to ToySoft).
    - DM8000 has no more gsod's now (thanks to ToySoft for testing!)
    Changes compared to openpli-oe-core gst-1:
    - Ships with gstreamer upstream master git:
    Using the same patches as openpli-oe-core gst-1 with only these changes:
    Removed: 0001-baseparse-post-tag-list-when-avg-bitrate-changes-at-.patch
    because this patch was already checked in upstream.
    Added: 0001-Revert-qtdemux-respect-qt-segments-in-push-mode-for-.patch
    By mx3L which fixes mp4 playback from remote locations.
    - Every receiver uses christophecvr's multibox dvbmediasink.
    - Using libtrmp and rtmpdump from oe-alliance.
    - Some small enigma2 patches for Dreambox receivers (ac3/dts bypass and blanking on zap support).
    These are only applied for Dreambox receivers.
    - AAC to AC3 transcoding V2 by mx3L (requires a fast cpu).
    - IPTV Player from samsamsam included (thx to Athoik for the recipe).
    - Large list of public IPTV streams included thanks to the Japhar Team.
    - Updated libcdio and cdtextinfo for audio-cd support by christophecvr.
    - DM800Se, DM7020HD and DM800SeV2 driver upgraded to 20151201:
    added si2166b blindscan support
    - Spark images includes the pti.ko from OpenATV so softcam's should work now.
    - Using aio-grab source from oe-alliance which includes fixes for spark receivers.
    - The 2.6.18 kernel will now always pass the vermagic check when loading modules.
    Now you can try and load any kernel driver from OE1.5 to 2.0.
    Known issues:
    - DM800 first boot will take a while, please be patient. The next boot will be faster.
    - On spark/spark7162 you need to set 'boxtype = dreambox' for oscam dvbapi.
    We're using the OE-A drivers and 'duckbox' doesn't seem to work on these.
    - On spark/spark7162 you need to set a skin which doesn't resize the framebuffer.
    Because sometimes it doesn't scale back to fullscreen.
    I've included the MX-HQ7 skin for use as workaround.
    - On Zgemma Star you cannot use fullHD skins.
    This is a hardware/driver limitation.
    Please don't try it, it will crash enigma2.
    - Some Dreambox remotes behave very sensitive.
    This causes button presses to register multiple times instead of just once.
    As a workaround you can adjust the key interval:
    Go to: Menu - System - Input devices - dreambox remote control (native).
    Set "Change repeat and delay settings" to yes
    Set "Interval between keys when repeating:" to 200ms or 300ms.
    Press green button (OK)
    Now set the same delay for: "dreambox advanced remote control (native)" as well.
    To find the download link, search for MastaG Japhar OpenPLi 4.0
    Enjoy !
    toysoft's Avatar
    Nov 2008
    Changes :
    - Gstreamer 1.7.1
    The mp4 playback from remote urls has been fixed upstream so no more revert for that.
    libsoup http-handler has been updated so also no revert for that as well
    - New libsoup handler for http urls
    - New winter logo
    - More free space laugh
    Ive added a dirty hack that will upx compress the binary before package_write_ipk
    We now have 2 to 3MB more free space (very nice, great success)
    - New xvid/divx5 bitstream unpacker by mx3L, this should fix avi files with wrong fourcc
    - The usual batch of dvbmediasink fixes by christophecvr and mx3L
    - Wifi drivers have been refactored a bit, I dont auto-load the rt7777 anymore.
    it should kick in when you plugin your wifi stick.
    If not then Ill create a ppanel which will allow you to choose which driver you want to use: rt3070, rt55xx or rt7777 (since they cant be loaded at the same time)
    by MastaG
    DM8000HD: https://mega.nz/#!YRklVADa!jfV_0mM-6...zLFubOFmA7VCAg
    DM800HDse : https://mega.nz/#!BAtCwQ4R!r15VnQlfK...nDNfLsp9CQBYbU
    DM800HD : https://mega.nz/#!kYlVHRoD!pWuty-xvl...6iGabO8Dk77bno
    DM500HD : https://mega.nz/#!VMcAyQwC!Z4CxifG_3...GSS8MW90MLYBkc
    Feel free to post images on all your satellite forums you like and share with all your friends these excellent tools and new images with full IPTV support, the best around, even better than on original boxes !!! Thank you !
    Sep 2016
    U.S.
    Default SuperSim Japhar DM500HD OpenPLi 4 0 for Japhar NC3 Sim SEPTEMBER 2015
    maybe a stupid question, but is this the ordinary estar v3?or do I have another sim for this? SuperSim
    toysoft's Avatar
    Nov 2008
    estar is now dead since 2 year, they closed all, support forum etc. It's the Japhar SuperSim3 NC3 Sim.
    TS
    Quote Originally Posted by AlexmenTund View Post
  7. The Following User Says Thank You to toysoft For This Useful Post:
    mohaadben (19th December, 2016)
    Dec 2015
    [QUOTE = toysoft؛ 2860565] ESTAR هو الآن ميت منذ 2 سنة، ولكنها أغلقت جميع، دعم المنتدى الخ انها Japhar SuperSim3 NC3 سيم.
    TS [/ QUOTE]
    شكرا
