missing channels
Results 1 to 5 of 5
    Nov 2010
    Default missing channels
    Without breaking any rules can anyone assist me with this one
    Did a service scan but i haven't picked up certain channels that I had before. I did not change any settings prior to doing the scan and have done a scan several times and never had this problem before. I notice in the settings on Commando that you can change from all satellites to astra etc which setting will pick up every channel on Astra. I am using the Commando image which is up to date.
    Thanks in advance.
    digicon's Avatar
    what sort of satellite connection do you have Fixed dish @ 28.2? east or Motorised or Multi-LNB install, by default the image is set to a fixed 28.2? east install
    Nov 2010
    I have a fixed dish at 28.2 with single lnb and using a blackbox 500
    DK Veteran psats's Avatar
    Sep 2008
    If you are useing the updated img
    http://www.digital-kaos.co.uk/forums...00C-test-image
    you only need to use autobouquets
  5. The Following 2 Users Say Thank You to psats For This Useful Post:
    dave74863 (19th September, 2015), digicon (20th September, 2015)
    Nov 2010
    Sorry it has taken so long to reply been a bit busy with other things. Just wanted to say thanks for the info I didn't have the latest Commando image I only had the 15 which was telling me it was bang up to date. I erased that and installed 15.1 and after setting my locals and autobouquets the missing channels have come back.
    Cheers
