Guide: How to Create a DM500 Dreambox Image - Page 12
Page 12 of 12 FirstFirst ... 2789101112
Results 166 to 174 of 174
  1. #166
    May 2012
    Quote Originally Posted by louis1170 View Post
    Hi LraiZer,
    I have followed you suggestion and i tried to create the image using the new and updated way. Unfortunately i still have the same problem.
    [ -x /home/louis3785/tuxbox-cvs/cdk/root-enigma-squashfs-local.sh ] && KERNEL=2.6 KERNELVERSION=2.6.9 LIBC=glibc BOXTYPE=dreambox BOXMODEL=dm500 /home/louis3785/tuxbox-cvs/cdk/root-enigma-squashfs-local.sh /home/louis3785/tuxbox-cvs/root/cdkflash /home/louis3785/tuxbox-cvs/cdk || true
    /usr/bin/install -c linux-2.6.9/arch/ppc/boot/images/zImage.treeboot /home/louis3785/tuxbox-cvs/root/cdkflash/boot/root/platform/kernel/os
    mv /home/louis3785/tuxbox-cvs/root/cdkflash/boot/root/platform/kernel/bild .
    /home/louis3785/tuxbox-cvs/root/cdk/bin/mkcramfs-e -eb /home/louis3785/tuxbox-cvs/root/cdkflash/boot /home/louis3785/tuxbox-cvs/root/cdkflash/boot-cramfs.img
    /bin/bash: /home/louis3785/tuxbox-cvs/root/cdk/bin/mkcramfs-e: No such file or directory
    make: *** [/home/louis3785/tuxbox-cvs/root/cdkflash/boot-cramfs.img] Error 127
    Please advise.
    Thanks you in advance
    Louis
    This error confused me to at first, but actually there is a binary called "mkcramsfs-e".
    Its a 32-bit binary, and if you are running a 64-bit linux, you get the error "No such file or directory" when you try to run it.
    I installed a 32-bit linux version on a spare harddrive, but maybe there is some way to run 32-bit binaries on 64-bit linux too.
  2. #167
    May 2012
    Quote Originally Posted by amaru View Post
    Hello!
    I'm trying to compile openpli image for DM500, but there are some errors. Could you please help?
    /bin/sh ./libtool --mode=compile --tag=CC powerpc-tuxbox-linux-gnu-gcc   -g -O2 -DSQLITE_OS_UNIX=1 -I. -I./src -D_HAVE_SQLITE_CONFIG_H -DNDEBUG   -DSQLITE_THREADSAFE=0 -DSQLITE_THREAD_OVERRIDE_LOCK=-1 -DSQLITE_OMIT_LOAD_EXTENSION=1  -c ./src/alter.c
    ./libtool: 1639: preserve_args+= --tag CC: not found
    eval: 1: base_compile+= powerpc-tuxbox-linux-gnu-gcc: not found
    eval: 1: base_compile+= -g: not found
    eval: 1: base_compile+= -O2: not found
    eval: 1: base_compile+= -DSQLITE_OS_UNIX=1: not found
    eval: 1: base_compile+= -I.: not found
    eval: 1: base_compile+= -I./src: not found
    eval: 1: base_compile+= -D_HAVE_SQLITE_CONFIG_H: not found
    eval: 1: base_compile+= -DNDEBUG: not found
    eval: 1: base_compile+= -DSQLITE_THREADSAFE=0: not found
    eval: 1: base_compile+= -DSQLITE_THREAD_OVERRIDE_LOCK=-1: not found
    eval: 1: base_compile+= -DSQLITE_OMIT_LOAD_EXTENSION=1: not found
    eval: 1: base_compile+= -c: not found
    libtool: compile: you must specify a compilation command
    libtool: compile: Try `libtool --help --mode=compile' for more information.
    make[1]: *** [alter.lo] Error 1
    make[1]: Leaving directory `/home/amaru/test/openplisvn/trunk/cdk/cdk/sqlite-3.6.4'
    make: *** [.sqlite] Error 2
    What am I doing wrong?
    I got this error to, its seems to be something with libtool and dash if i remember the thread correctly.
    Running
    export CONFIG_SHELL="/bin/bash"
    fixed it for me.
  3. #168
    Apr 2011
    Hello friends , iam new to this , i try to make the image but i see some errors ... :
    dreambox@ubuntu:~/tuxbox-cvs/cdk$ make dreamboximage_root
    /usr/bin/install -c -d /home/dreambox/tuxbox-cvs/root/cdk/powerpc-tuxbox-linux-gnu
    /usr/bin/install -c -d /home/dreambox/tuxbox-cvs/root/tftpboot
    rm /home/dreambox/tuxbox-cvs/root/cdk/powerpc-tuxbox-linux-gnu/include
    rm: cannot remove `/home/dreambox/tuxbox-cvs/root/cdk/powerpc-tuxbox-linux-gnu/include': No such file or directory
    make: [.directories] Error 1 (ignored)
    rm /home/dreambox/tuxbox-cvs/root/cdk/powerpc-tuxbox-linux-gnu/lib
    rm: cannot remove `/home/dreambox/tuxbox-cvs/root/cdk/powerpc-tuxbox-linux-gnu/lib': No such file or directory
    ln -s /home/dreambox/tuxbox-cvs/root/cdkroot/include /home/dreambox/tuxbox-cvs/root/cdk/powerpc-tuxbox-linux-gnu/include
    ln -s /home/dreambox/tuxbox-cvs/root/cdkroot/lib /home/dreambox/tuxbox-cvs/root/cdk/powerpc-tuxbox-linux-gnu/lib
    /usr/bin/install -c -d /home/dreambox/tuxbox-cvs/root/cdkflash
    if [ -e NONE/ccache ]; then \
    /usr/bin/install -c -d /home/dreambox/tuxbox-cvs/root/cdk/ccache-bin ;\
    ln -s NONE/ccache /home/dreambox/tuxbox-cvs/root/cdk/ccache-bin/powerpc-tuxbox-linux-gnu-gcc ;\
    ln -s NONE/ccache /home/dreambox/tuxbox-cvs/root/cdk/ccache-bin/powerpc-tuxbox-linux-gnu-g++ ;\
    ln -s NONE/ccache /home/dreambox/tuxbox-cvs/root/cdk/ccache-bin/powerpc-tuxbox-linux-gnu-cpp ;\
    ln -s NONE/ccache /home/dreambox/tuxbox-cvs/root/cdk/ccache-bin/powerpc-tuxbox-linux-gnu-gcc-.3.4.4 ;\
    fi
    touch .directories
    false || \
    wget -c --passive-ftp -P Archive ftp://ftp.kernel.org/pub/linux/devel...91.0.2.tar.bz2 || \
    wget -c -P Archive http://tuxbox.berlios.de/pub/tuxbox/...91.0.2.tar.bz2
    --2012-06-19 13:37:44-- ftp://ftp.kernel.org/pub/linux/devel...91.0.2.tar.bz2
    => `Archive/binutils-2.15.91.0.2.tar.bz2'
    Resolving ftp.kernel.org (ftp.kernel.org)... 149.20.4.69
    Connecting to ftp.kernel.org (ftp.kernel.org)|149.20.4.69|:21... connected.
    Logging in as anonymous ... Logged in!
    ==> SYST ... done. ==> PWD ... done.
    ==> TYPE I ... done. ==> CWD (1) /pub/linux/devel/binutils ... done.
    ==> SIZE binutils-2.15.91.0.2.tar.bz2 ... done.
    ==> PASV ... done. ==> RETR binutils-2.15.91.0.2.tar.bz2 ...
    No such file `binutils-2.15.91.0.2.tar.bz2'.
    --2012-06-19 13:37:48-- http://tuxbox.berlios.de/pub/tuxbox/...91.0.2.tar.bz2
    Resolving tuxbox.berlios.de (tuxbox.berlios.de)... 193.175.135.82
    Connecting to tuxbox.berlios.de (tuxbox.berlios.de)|193.175.135.82|:80... connected.
    HTTP request sent, awaiting response... 404 Not Found
    2012-06-19 13:37:48 ERROR 404: Not Found.
    make: *** [Archive/binutils-2.15.91.0.2.tar.bz2] Error 8
    Please Can you help me ?
    Thanks a lot .
  4. #169
    I have the same problem.
    I downloaded binutils-2.15.91.0.2.tar.bz2 placed in on /tuxbox-cvs/cdk and run make dreamboximage_root and got the same error.
    I also want to update libssl0.9.7 to libssl0.9.8
    but first I have to solve the error with binutils
    Can someone please help us on the right directon.
    thank you.
    Rafiek
  5. #170
    Dec 2011
    Question little help please
    ive done everything it says here and even had to download some of the files it couldnt find cause the site was down, but ive got to a point i just cant google for an answer, this is what it says when the errors start appearing:
    In file included from fontrenderer.cpp:32:
    fontrenderer.h:46: error: `FTC_ImageTypeRec' does not name a type
    fontrenderer.h:79: error: `FTC_ImageType' has not been declared
    fontrenderer.h:79: error: ISO C++ forbids declaration of `font' with no type
    fontrenderer.cpp:132: error: `FT_Error LcdFontRenderClass::getGlyphBitmap' is not a static member of `class LcdFontRenderClass'
    fontrenderer.cpp:132: error: `FTC_ImageType' was not declared in this scope
    fontrenderer.cpp:132: error: expected primary-expression before "glyph_index"
    fontrenderer.cpp:132: error: expected primary-expression before '*' token
    fontrenderer.cpp:132: error: `sbit' was not declared in this scope
    fontrenderer.cpp:132: error: initializer expression list treated as compound expression
    fontrenderer.cpp:132: error: expected `,' or `;' before '{' token
    fontrenderer.cpp: In constructor `LcdFont::LcdFont(CLCDDisplay*, LcdFontRenderClass*, void*, int)':
    fontrenderer.cpp:180: error: `font' undeclared (first use this function)
    fontrenderer.cpp:180: error: (Each undeclared identifier is reported only once for each function it appears in.)
    fontrenderer.cpp:183: error: `FT_LOAD_TARGET_MONO' undeclared (first use this function)
    fontrenderer.cpp: In member function `FT_Error LcdFont::getGlyphBitmap(FT_ULong, FTC_SBitRec_**)':
    fontrenderer.cpp:188: error: `font' undeclared (first use this function)
    fontrenderer.cpp: In member function `void LcdFont::RenderString(int, int, int, const char*, int, int, bool)':
    fontrenderer.cpp:241: error: `FTC_ScalerRec' undeclared (first use this function)
    fontrenderer.cpp:241: error: expected `;' before "scaler"
    fontrenderer.cpp:243: error: `scaler' undeclared (first use this function)
    fontrenderer.cpp:243: error: `font' undeclared (first use this function)
    fontrenderer.cpp:248: error: `FTC_Manager_LookupSize' undeclared (first use this function)
    fontrenderer.cpp: In member function `int LcdFont::getRenderWidth(const char*, bool)':
    fontrenderer.cpp:318: error: `FTC_ScalerRec' undeclared (first use this function)
    fontrenderer.cpp:318: error: expected `;' before "scaler"
    fontrenderer.cpp:319: error: `scaler' undeclared (first use this function)
    fontrenderer.cpp:319: error: `font' undeclared (first use this function)
    fontrenderer.cpp:324: error: `FTC_Manager_LookupSize' undeclared (first use this function)
    make[3]: *** [fontrenderer.lo] Error 1
    make[3]: Leaving directory `/home/matthew/tuxbox-cvs/apps/tuxbox/libs/liblcddisplay'
    make[2]: *** [all-recursive] Error 1
    make[2]: Leaving directory `/home/matthew/tuxbox-cvs/apps/tuxbox/libs'
    make[1]: *** [all] Error 2
    make[1]: Leaving directory `/home/matthew/tuxbox-cvs/apps/tuxbox/libs'
    make: *** [.tuxbox_libs] Error 2
    matthew@ubuntu:~/tuxbox-cvs/cdk$
    what havent i got installed? and btw, this is my first time with a linux build so im still in the learning stages
    any help would be greatly appreciated
  6. #171
    Sep 2012
    hello
    i have this error after
    make[3]: *** [fontrenderer.lo] Erreur 1
    make[3]: quittant le r?pertoire ? /home/sony/tuxbox-cvs/apps/tuxbox/libs/liblcddisplay ?make dreamboximage_root
    make[2]: *** [all-recursive] Erreur 1
    make[2]: quittant le r?pertoire ? /home/sony/tuxbox-cvs/apps/tuxbox/libs ?
    make[1]: *** [all] Erreur 2
    make[1]: quittant le r?pertoire ? /home/sony/tuxbox-cvs/apps/tuxbox/libs ?
    make: *** [.tuxbox_libs] Erreur 2
    plz help me
  7. #172
    Oct 2012
    Sweden
    I to have the same problem!
    Any one know what to do?
    //Nicklas
  8. #173
    can someone please upload all needed files to a thebox account or dropbox then we could all start on the same page the rapidshare is un reliable.
    PS of course once uploaded you would post just one link to the file folder and we could all get every file
  9. #174
    Jan 2012
    I have read this thread. I am able to fully compile image(s) using the documentation here.
    However, my git checkout does not support the make dreamboximage_root profile, it now has these flash-all-* profiles.
    like flash-all-cramfs-1x, etc etc.
    My main problem is that it produces an 8mb flash image, which is 3mb too big for my dm500s. I have been trying to cut down the images folder to get it to fit.
    Second, I'm not sure why it makes .img1x and .img2x versions of the file, and which one I can flash. Trust me, I've tried to flash both, but because of the size difference, neither will be accepted by dreamup.
    Any ideas what I can do to get the image to the < 5mb level (comparable to the OpenPLi dm500s build -- which does the same problems for me, too)
    Best,
    -- pepinw
