Page 3 of 12 FirstFirst 12345678 ... LastLast
Results 31 to 45 of 174
  1. #31
    Sep 2008
    hi devilfish
    /etc/init.d/init1
    /bin/showlogo/ /bin/bild
    this is right or ?
    i copyed it from the /etc/init.d/rcS
    no picture =( suckx hard :x don't knew now what i can try =(
    edit: just another quest .
    is it possible to make the .img not as read-only filesystem ?
  2. #32
    Administrator
    Devilfish's Avatar
    Feb 2008
    /cdk
    /etc/init.d/init1
    Don't put the trailing slash after showlogo...
    /etc/init.d/init1
    /bin/showlogo /bin/bild
    Also make sure the 'showlogo' file is in /bin too.
    Did you put the bild file in /bin and make it chmod 755?
    No, only the /var folder is read/write. That's just the way enigma is.
  3. #33
    Sep 2008
    Default what about clones?
    I follow the procedure and make a simple image for my dm 500 and know i will try to put plugins and other stuff.
    But it is important for me to know if this image i create can harm other peoples who don't have the original dm 500?
    thnx in advance
  4. #34
    Administrator
    Devilfish's Avatar
    Feb 2008
    /cdk
    As far as I know, it will work on clone boxes ok.
  5. #35
    Sep 2008
    hi,i need add the "arp" command into my box,how can i do? thanks !!!!
  6. #36
    Dreambox Guru osborne82's Avatar
    Mar 2008
    any dreambox development forum
    Quote Originally Posted by killunix View Post
    edit buysbox.config in /cdk/patches
    u can add/ remove alot of things from here buddy
    cheers
    osborne82
  7. #37
    Sep 2008
    Quote Originally Posted by osborne82 View Post
    cheers
    osborne82
    i did what you say,change the buysbox.config file,set the CONFIG_ARPING=y,I can compired and get the image. but i need the "arp" command to change my dreambox's gateway's MAC address, the "ARPING" command can't do it,and the busysbox.config file has not the CONFIG_ARP option,i added it, but cann't compiled.
    anyone can tell me how can i add the arp command into box? or tell me how can i compile the arp.c
    thank you very much!!
  8. #38
    Nov 2008
    Thank you, my brothers of the subject, and I have distinct consequences for the inquiry files that were downloaded from the site where the author Rabid Sher Bay course because I use ubunto 8.10
  9. #39
    V.I.P. Member satman's Avatar
    Jun 2008
    Never Never Land
    if you have the .c source why cant you cross-compile it using the gcc and stuff in /root/cdk folder,,,
    boom!
  10. #40
    Nov 2008
    cvs-d anoncvs@cvs.tuxbox.org: / cvs / tuxbox-z3 co-P-rdreambox.
    This step does not respond and I think the problem of the same biographical Is it a solution to this problem
  11. #41
    Administrator
    Devilfish's Avatar
    Feb 2008
    /cdk
    The command you've typed above is wrong...this is the correct command...
    cvs -d anoncvs@cvs.tuxbox.org:/cvs/tuxbox -z3 co -P -rdreambox .
    Remember the dot at the end.
  12. #42
    Nov 2008
    Do you say thank you to my brother and I put the same is now set by the same problem and I do not respond and give me the following
    exclusive@ubunto:~/tuxbox-cvs$ cvs -d anoncvs@cvs.tuxbox.org:/cvs/tuxbox -z3 co -P -rdreambox .
    ssh: connect to host cvs.tuxbox.org port 22: Connection timed out
    cvs [checkout aborted]: end of file from server (consult above messages if any)
  13. #43
    Administrator
    Devilfish's Avatar
    Feb 2008
    /cdk
    Looks like the tuxbox server was unavailable at the time.
    Maybe try again in 24hrs.
  14. #44
    Nov 2008
    y sir thank you for your cooperation and your good
    And they have not forgotten all appreciation and respect
    Accept greetings
    Cheers
  15. #45
    Nov 2008
    exclusive@exclusive-desktop:~$ mkdir tuxbox-cvs
    mkdir: cannot create directory `tuxbox-cvs': File exists
    Devilfish
    Administrator
    exclusive@exclusive-desktop:~$ cd tuxbox-cvs
    exclusive@exclusive-desktop:~/tuxbox-cvs$ export CVS_RSH=ssh
    exclusive@exclusive-desktop:~/tuxbox-cvs$ cvs -d anoncvs@cvs.tuxbox.org:/cvs/tuxbox -z3 co -P -rdreambox .
    anoncvs@cvs.tuxbox.org's password:
    This step of my sir
    The problem is that he asked password
    I know
    Please help me
