Page 2 of 12 FirstFirst 1234567 ... LastLast
Results 16 to 30 of 174
  1. #16
    Administrator
    Devilfish's Avatar
    Feb 2008
    /cdk
    Manually download the file and place it in the Archive folder - click the above link, save as, and drag it into the Archive folder.
    Then, when you do a 'make dreamboximage_root' it will continue from where it left off. It will look to see if you have the package, if you don't, it will try to download it, if you do, it will continue to the next package. Since you already have that package in the Archive folder, it will jump to the next package.
    Get Digital Kaos on your Apple or Android device with Tapatalk
  2. #17
    Jul 2008
    thanks again for help. now to customization part. what is possible to customize anyway? emus? .mostly i use mgcam for what. i dont need visual part.sorry my english. what ever i can do? best part will be porting mpeg4 codec.!? dreaming? any suggestion welcome. maybe it will be
  3. #18
    Sep 2008
    Default emus
    how i get installed emus on this image ?
    btw n1 howto searched for a while!
    love it
  4. #19
    Administrator
    Devilfish's Avatar
    Feb 2008
    /cdk
    You can either use an emu manager or you can manually start the emu on bootup.
    There are a few forums who don't allow emu talk but if you google 'dreambox nemesis source' you should get the source code that the Nemesis team have released to the public, this has an emu manager in it.
    If you only want to run one emu, lets say it's evocamd. Put the evocamd file in /bin (or wherever you want). Edit the /etc/init.d/rcS file to include this line...
    /bin/evocamd &
  5. #20
    Sep 2008
    hi guys,
    when i do the command " make dreamboximage_root " it compiles just to one special poitn and then he repeat it everytime...
    make[1]: leave folder '/root/tuxbox/tuxbox-cvs/apps/tuxbox/libs'
    make[1]: go to folder '/root/tuxbox/tuxbox-cvs/apps/tuxbox/libs'
    make[1]: warning: File 'Makefile.am' change 1,4e+02 s in the future
    cd . && /bin/bash /root/tuxbox/tuxbox-cvs/apps/tuxbox/libs/missing --run aclocal-1.10
    cd . && /bin/bash /root/tuxbox/tuxbox-cvs/apps/tuxbox/libs/missing --run automake-1.10 --gnu
    cd . && /bin/bash /root/tuxbox/tuxbox-cvs/apps/tuxbox/libs/missing --run autoconf
    i have done the procedere this morning and all went fine :x
    hope u can help me
    solved from alone :x don't knew what it was but now it's all fine
  6. #21
    Sep 2008
    good morning,
    when i do changes in the files, it do not save anything when i do finally ' make flash-compress '
    somebody can help me ?
  7. #22
    Dreambox Guru osborne82's Avatar
    Mar 2008
    any dreambox development forum
    Quote Originally Posted by ~~~~age View Post
    good morning,
    which files u edting and have u
    cd cdk
    rm .enigma
    make .enigma
    then make rebuild etc then flash compress
    should include your changes
    cheers
    osborne82
  8. #23
    Administrator
    Devilfish's Avatar
    Feb 2008
    /cdk
    Also, if you are backing up /cdkflash/root before you do a 'rm enigma' ( do this then copy it back after a 'make rebuild-flash') remember to NOT copy over the previous /bin/enigma file as this doesn't have any of your changes.
    This caugt me out for quite a while and I couldn't work out why .
  9. #24
    Sep 2008
    yeah now it works all fine openvpn & some other specials are running and i'm reallllly happy
    now i'm just do different thinks to be more happy :P
    when u will i cann write an howto to integrate openvpn into the image.
    there are some difficult things.
  10. #25
    Administrator
    Devilfish's Avatar
    Feb 2008
    /cdk
    thank you ~~~~age, that would be good.
  11. #26
    Sep 2008
    silly quest ... but where do i put the picture of the background into ?
    just into /var/tuxbox/config/enigma/pictures ? or into
    /tuxbox-cvs/root/cdkflash/boot/root/platform/kernel ?
    i have just put it into both but nothing happend :x
    I will write an Howto when everything works fine and i have time to write
  12. #27
    Administrator
    Devilfish's Avatar
    Feb 2008
    /cdk
    It should go in /root/platform/kernel and is called bild.
    Is it the right resolution, etc.?
    http://www.digital-kaos.co.uk/forums...own-logos-587/
  13. #28
    Sep 2008
    yeah i have done the "bild" with the howto in this thread and put it in there... but nothing happend :x
  14. #29
    Mar 2008
    Quote Originally Posted by Devilfish View Post
    pmsl yip i remeber that ol
  15. #30
    Administrator
    Devilfish's Avatar
    Feb 2008
    /cdk
    Just put the bootup pic in /bin and add a line in /etc/init.d/rcS to load it.
    Look for:
    /etc/init.d/init1
    Add this after the above line:
    /bin/showlogo /bin/bild
