Ford Transit Connect SID 206 DTC OFF HELP
Results 1 to 9 of 9
    dominik.m's Avatar
    Jun 2009
    POLAND
    Default Ford Transit Connect SID 206 DTC OFF HELP
    HI ALL.
    Somebody can help remove DTC P1335 from this ecu?
    Thanks.
    Salute.
    bulanbulanov's Avatar
    Italy, Abruzzo, Teramo
    Quote Originally Posted by dominik.m View Post
    HI ALL.
    Thanks.
    Salute.
    must be a complete BDM file !!!
    Sep 2015
    belgium
    HI
    you have probleme with EGR ??
    you delete egr or not ??
    possible you kill dtc but if you are not egr block, you have problem with car
    if you have I send you egr block
    dominik.m's Avatar
    Jun 2009
    POLAND
    Carfiles If You can. Remove Egr.
    Sep 2015
    belgium
    send me information for car
    motor?
    years?
    and with wich program read file ?
    dominik.m's Avatar
    Jun 2009
    POLAND
    1.8TDCI 2009r
    Read by OBD2 FGtech
    carmageddon's Avatar
    Italy
    HI ALL.
    Thanks.
    Salute.
    P1335 = set to zero from address 75F88 to address 75F95 and from 76940 to 76948 @ 8 bit
    egr = set to zero from address 72462 to 724C0 16 bit
  8. The Following 4 Users Say Thank You to carmageddon For This Useful Post:
    bobolin4o (18th September, 2015), CLK1201 (18th September, 2015), dominik.m (18th September, 2015), sazimam11 (4th May, 2017)
    Senior Member sazimam11's Avatar
    Jan 2012
    Praha, Czech republic
    ... you meant : ... and from 76940 to 7694B...
  10. #9
    Oct 2012
    [QUOTE = carmageddon; 2601657] P1335 = attivato su zero dall'indirizzo 75F88 con 75F95 e da 76940 a 76948 @ 8 bit
    egr = attivato su zero dall'indirizzo 72462 a 724C0 16 bit [/ QUOTE]
    ciao mi puoi controllare questo file il mezzo sembra andar bene fino ai tremila giri dopo sembra che i muri impiega molto a salire di giri
    hai un damos?
