Hello all
i have same problem, the n disappeared on my Yaris mmt. Can anyone help please.
Hello all
Also can anyone please tell me which eeprom I need to reload??
check transistors for clutch actuator and selector motors
many time i found burned transistors
Thanks for reply Vasko mate.
i will check the transistors tomorrow .
is it any chance you can tell me if the eeprom on this is 8pin one or more??
i can read and write the eeproms but I don’t know which one I need to rewrite.
i would really appreciate if you can point me in the right direction.
thanks.
thanks.
Vasko Ure dump is in x16 or x8?
Im looking for learned dump for 89530-70090
Asin 324811-13550
I have Toyota Aygo 2011 ( model KGB10R )with MMT . There was Clutch and bearing noise at the time of especially upshifting.I initialized the clutch cover by using GTS. but after that the GEAR POSITION INDICATOR from the combination meter display disappeared. i have done calibration multiple times but there is no activity in the display. the car is not even shifting the gear and is not moving. please what is this happening and how to get rid of this situation. is this EEPROM problem or something else if yes then from where i will found learned EEPROM for TOYOTA AYGO 2011 MMT ECU part # 89530-70100.? Plese Help
Hi, I have ToyotaAygo KGB10r with MMT. there was slip shifting problem i.e., a slipping noise and gear rattling noise heard mostly at the time of upshifting. i tried to calibrate its clutch cover with the help of Global Tech Stream. but as i performed calibration , the GEAR POSITION INDICATOR from the Combination meter display disappeared. now vehicle is shifting any gear and not moving at all. i have read your forum posts and think that you may have some idea about such fault.so kindly guide me in this course that why this problem caused like this . i am an automotive professional but have never seen such mmt transmissions. Please tell if its eeprom is corrupt and from where can i aquire this again?
hi, i have toyota Aygo 2011 KGB10R with MMT ECU: 89530-70100 . I need learned EEPROM Dump. there is some calibration issue as no gear position shift indicator display in the combination meter even after dozens of time re calibration performed. no gear is being shifted.neither clutch nor transmission is being calibrated.I have used GTS and manual calibration method too(http://www.blue-print.com/mmt/INF134...65_266_274.pdf) . Need assistance in this problem.Thanks
i have desolder the eprom.but cant whrite it.whats the trick to whrite it?
PUT THE EEPROM IN THE CORRECT ORIENTATION INTO THE EEPROM CHIP HOLDER AND INSERT THE HOLDER INTO THE IC PROGRAMMER. THEN FIRST OF ALL READ IT TO SEE WHAT IS INSIDE YOUR EEPROM CURRENTLY.AND SAVE IT WHAT SO EVER IT WILL BE. THEN ERASE THE EEPROM AND THEN OPEN THE PROGRAM YOU WANT TO WRITE AND CLICK ON 'P' ICON TO WRITE THE PROGRAM INTO THE CHIP. AND THIS IS THE WHOLE STORY.THIS WILL BE A MATTER OF SECONDS TO WRITE A CHIP.
i have change the clutch kit , ecu is toyota 89530-52160 , i have write your file , car is alive , but it start moving very bad same as at E and R ... how is possibile ?! thanks
Hi Vasko,
What programmer i need for writing of the dump file?
Thx
