Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 51
  1. #16
    Nov 2017
    Hello all
    i have same problem, the n disappeared on my Yaris mmt. Can anyone help please.
  2. #17
    Nov 2017
    Also can anyone please tell me which eeprom I need to reload??
  3. #18
    vasko's Avatar
    Nov 2011
    Gotze Delchev
    check transistors for clutch actuator and selector motors
    many time i found burned transistors
  4. #19
    Nov 2017
    Thanks for reply Vasko mate.
    i will check the transistors tomorrow .
    is it any chance you can tell me if the eeprom on this is 8pin one or more??
    i can read and write the eeproms but I don’t know which one I need to rewrite.
    i would really appreciate if you can point me in the right direction.
    thanks.
  5. #20
    Nov 2017
    Quote Originally Posted by vasko View Post
    thanks.
  6. #21
    Nov 2017
    I have checked the resisters but found all of them good.
    now I really need your help.
  7. #22
    Jun 2013
    Vasko Ure dump is in x16 or x8?
    Im looking for learned dump for 89530-70090
    Asin 324811-13550
  8. #23
    Feb 2018
    Default TOYOTA AYGO MMT GEAR POSITION INDICATOR DISAPPEARED
    I have Toyota Aygo 2011 ( model KGB10R )with MMT . There was Clutch and bearing noise at the time of especially upshifting.I initialized the clutch cover by using GTS. but after that the GEAR POSITION INDICATOR from the combination meter display disappeared. i have done calibration multiple times but there is no activity in the display. the car is not even shifting the gear and is not moving. please what is this happening and how to get rid of this situation. is this EEPROM problem or something else if yes then from where i will found learned EEPROM for TOYOTA AYGO 2011 MMT ECU part # 89530-70100.? Plese Help
  9. #24
    Feb 2018
    Quote Originally Posted by dariobmw View Post
    Good morning i need help from a good toyota expert , i bought a toyota corolla with MMT transmission
    and the clutch fried , after some time the car was on my garage a friend told , sell to me that .......
    and now the problem started !
    i detached the battery and changed the clutch , start the car ( from here all ok ) and a not good clutch
    release was the first symptom (the car before run good but the clutch slip from all gears but no errors
    on dash ) .
    So the intention was to make a adaption to the clutch actuator (like the smart) and with the diagnostic
    connected ,after the adaption the N on the dash disappeared OMG !!!!!!!!!! no more clutch no more
    gear actuator no more rpm over the idle , the strange is on the dash NO LIGHT ON but no N too .
    Now the car is a good ornament , and annoying to move .
    1st question WHY THE N DISAPPEARED ?
    2nd how can i make the car run again ?
    Please no answer to take some petrol and burn because i a big temptation !
    Hi, I have ToyotaAygo KGB10r with MMT. there was slip shifting problem i.e., a slipping noise and gear rattling noise heard mostly at the time of upshifting. i tried to calibrate its clutch cover with the help of Global Tech Stream. but as i performed calibration , the GEAR POSITION INDICATOR from the Combination meter display disappeared. now vehicle is shifting any gear and not moving at all. i have read your forum posts and think that you may have some idea about such fault.so kindly guide me in this course that why this problem caused like this . i am an automotive professional but have never seen such mmt transmissions. Please tell if its eeprom is corrupt and from where can i aquire this again?
  10. #25
    Feb 2018
    hi, i have toyota Aygo 2011 KGB10R with MMT ECU: 89530-70100 . I need learned EEPROM Dump. there is some calibration issue as no gear position shift indicator display in the combination meter even after dozens of time re calibration performed. no gear is being shifted.neither clutch nor transmission is being calibrated.I have used GTS and manual calibration method too(http://www.blue-print.com/mmt/INF134...65_266_274.pdf) . Need assistance in this problem.Thanks
  11. #26
    Jul 2010
    i have desolder the eprom.but cant whrite it.whats the trick to whrite it?
  12. #27
    Feb 2018
    PUT THE EEPROM IN THE CORRECT ORIENTATION INTO THE EEPROM CHIP HOLDER AND INSERT THE HOLDER INTO THE IC PROGRAMMER. THEN FIRST OF ALL READ IT TO SEE WHAT IS INSIDE YOUR EEPROM CURRENTLY.AND SAVE IT WHAT SO EVER IT WILL BE. THEN ERASE THE EEPROM AND THEN OPEN THE PROGRAM YOU WANT TO WRITE AND CLICK ON 'P' ICON TO WRITE THE PROGRAM INTO THE CHIP. AND THIS IS THE WHOLE STORY.THIS WILL BE A MATTER OF SECONDS TO WRITE A CHIP.
  13. #28
    Apr 2017
    i have change the clutch kit , ecu is toyota 89530-52160 , i have write your file , car is alive , but it start moving very bad same as at E and R ... how is possibile ?! thanks
  14. #29
    Jun 2015
    Hi Vasko,
    What programmer i need for writing of the dump file?
    Thx
  15. #30
    Oct 2018
    Quote Originally Posted by shailinb View Post
    Hi Dariobmw,
    I am having the same problem after changing clutch. No indicator on dash and only idle, no throttle response. Something went wrong during initialization.
    Did you ever get your clutch fixed? If yes then how?
    I looked at the nono94 method, but the corolla has a different actuator then the corolla (with two servo motors).
    Hi friend. Did you manage to sort out the mmt issue. I need help
