Thanks Nickolasd
The backup will be stored in x300m unit I guess itself so don't need an eeprom adapter to store.
Thanks Nickolasd
GM V30.48 update.
Nothing new has been added.
Probably bug fixes and improvements.
claudio35 (6th December, 2016), DashProg (8th December, 2016), Dr. Zoidberg (6th December, 2016), Nymike (6th December, 2016)
Nissan Pathfinder (altima) 2015,24c16, perfect works! km exactly and 2 min aprox, other models v30.57.-
I want to share my experience with hummer h3 2009
I have try last version. there is 2 type both read odometer mileage ok but when i write it still the same on dashboard
if you read again the mileage it will show on x100 the new mileage but in dash its still the old one.
Mileage in this truck ia stored in bcm and dash
i thought that x100 have do the dash only. so i have remove bcm to do it with other tool.
then I realized that x100 have do bcm and not dashboard. So i have removed dash and do it manually
then job complete
IF MY POST WAS HELPFUL DON'T FORGET TO GIVE ME LIKE AND REPUTATION... THAT WILL KEEP US HELPING OTHER'S
I have try to remove battery but nothing changed. I have not try to drive the truck. The problem is that i have thought that x100 have do the dash and not the bcm. But it was in opposite
was testing tool on a 2003 avalanche with latest software GM30.46, can read fine and tool tells me write fine but numbers don't change. tried few times, same problem. anybody came across similar issue.
mileage stored in cluster only on this vehicle, not bcm.
Ford Focus, C-Max in 2014, does it work?
Mazda 6 2002 10sec
Touareg 2008 30sec
Golf 4 2002
all successful done
kari11 (9th December, 2016)
as you say mate, mine works ok.
