Page 124 of 232 FirstFirst ... 2474114119120121122123124125126127128129134174224 ... LastLast
Results 1,846 to 1,860 of 3467
  1. #1846
    EU
    Anyone tried vw passat B8 mqbab VDO 01/2015?
  2. #1847
    hcip's Avatar
    From the heaven of paradise in the middle of happiness|hobby:__Bedtime| Sex:Female|Status:Not_Virgin
    Quote Originally Posted by Thos View Post
    Just did one today 2008 H3 Hummer
    1 - read correct mileage
    2 - input new mileage
    3 - disconnect battery
    4 - read mileage ( should read new mileage even though cluster still reads old mileage )
    5 - remove cluster and manualy set mileage on cluster same as bcm mileage
    6 - refit cluster and should show new mileage
    I did 3x in this procedure
    1 - Connect OBDStar and read mileage
    2 - Change to new mileage
    3 - remove Instrument cluster and set the mileage to zero manually
    4 - installed the cluster to a car, you will see zero value displayed from cluster,
    5 - switch ignition to ON position, the cluster takes mileag from BCM
    Stupidity is not a disease, because there are no existing hospitals for Idiots!
  3. The Following 4 Users Say Thank You to hcip For This Useful Post:
    alimmo (10th January, 2018), maybach_ (11th January, 2018), shirokov (9th January, 2018), teerak2uk (9th January, 2018)
  4. #1848
    EU
    tried vw passat B8 mqbab VDO 01/2015 - not work
  5. #1849
    shirokov's Avatar
    Cherkasy, Ukraine
    FORD/LINCOLN V30.45 update.
    New:
    Edge
    -2015
    Double Color meter
    New Mondeo
    Double Color meter (-2015)
  6. The Following User Says Thank You to shirokov For This Useful Post:
    DashProg (16th January, 2018)
  7. #1850
    drpeter's Avatar
    The Netherlands
    Quote Originally Posted by shirokov View Post
    New:
    Edge
    -2015
    Double Color meter
    New Mondeo
    Do you think they mean the new hybrid cluster (denso) also? See attachment
  8. #1851
    shirokov's Avatar
    Cherkasy, Ukraine
    Quote Originally Posted by drpeter View Post
    If it's Denso, then maybe we'll have to do it by hands, not by OBDII.
    I have not seen this kind of cluster yet.
  9. The Following 2 Users Say Thank You to shirokov For This Useful Post:
    DashProg (16th January, 2018), hcip (10th January, 2018)
  10. #1852
    hcip's Avatar
    -2015 (below 2015) edge double color meter = Dash with 93C86 SOT23
  11. The Following 2 Users Say Thank You to hcip For This Useful Post:
    DashProg (16th January, 2018), shirokov (10th January, 2018)
  12. #1853
    Oct 2017
    N Ireland
    Hi guys am I better with the x300 than x100 thanks in advance
    Sent from my VFD 900 using Tapatalk
  13. #1854
    Nicolas9's Avatar
    Feb 2017
    Aruba
    Yes 100%....
  14. #1855
    pierre renault's Avatar
    Jan 2013
    OBDSTAR X-100 PRO, not the most updates???
  15. #1856
    Dec 2017
    Good night
    Anyone test OBd x300M in a Golf 7 year 2013, I update the last version, janury 2018, and it is wrong I test with NEC35XXX 2014- and with 24C64 2014-
    I wait your answer
    thanks and happy new Year
  16. #1857
    Feb 2017
    Really good tool
    most key proramming works and milage to
    Audi A1 A5 A4 2012-2013 doesn't works...
    t
  17. #1858
    Feb 2017
    try v31.51 White odometer -this works in past
  18. #1859
    Sep 2016
    Hyundai I 30 2014 -No communication.
    Help is needed.
  19. #1860
    dimitar's Avatar
    Vw bora 2000 vdo cluster dont work
    Done with kkl cable and vag epromer
    50w Soldering Iron
    Chisel
    Sometimes Hammer
