Hello anyone already do this Dashboard Rang Rover Sport 2015 BY OBDSTAR
a52b5a5c-0b44-48cd-bfe6-f73961b35c77.jpg 29527582-2323-4d0b-a009-326abc9b937a.jpg e47d8ec3-a5d7-44a8-aef8-11bc319ea7c5.jpg
2014 Corolla - X300M fail Display says Does not support
I tried reading with all the Toyota but all said the same thing
Yesterday I tried on a 2013 Toyota Camry it read the mileage but was not correct
Thos
rtbdiagnostic (28th December, 2018)
Actual Toyota Corolla clusters there are two options from different manufacturers.
Those released by VDO Siemens can be adjusted by OBDII.
And those that are released Denso, you must disassemble.
None of the instrument clusters, which was released by Denso, can not be corrected by OBDII.
All instrument clusters that are installed on the all Camry model, are issued by Denso.
So don't wait for the cable solution. It's impossible.
Only the new XV70 series is equipped with a Denso or VDO clusters.
You can only adjust some panels, without disassembling the instrument cluster, connecting to the Denso control points.
But the Obdstar company does not release such a tool and will never release it.
111arm (9th November, 2019), DashProg (1st January, 2019), rtbdiagnostic (30th December, 2018)
passat b8 2015 can read but not write e say to use real key but car its keyless any solution??
Enviado do meu Redmi 5 Plus através do Tapatalk
svallecilla (6th April, 2020)
Sent from my ANE-LX1 using Tapatalk
2014 which month? D70F35XX dashboard? @Thos
ford focus c max I and c max II dont work with newest update x300m, older updates work ok.
Has Anyone Do Correction Dashboard For Peugeot 301 By OBDSTAR X300DP ?
OBDSTAR-X300-DP-PAD-Tablet-Vert-Cl-Programmeur-Standard-Configuration-Immobilisation-Ajustement-.jpg
