a class, b class, cla up to 2015 read km ok, but write fails. Has it ever worked for somebody?
No!!
you have to play with EZS....also!!
Tried today Ford cmax 2015 and fiat ducato 2017 work fine
Envoyé de mon LYA-L29 en utilisant Tapatalk
car has x km after correction, few months ago car was at a service at a dealer with x multiplied by 5times km, that is the biggest isseue most people miss most of the times : . Doing dash km properly is a basis for proper job, need to do assyst, ecu, airbag ecu hours(then it is all original, people should stop playing with used clusters, then there would be easier job to correct the car)... not easy job for the unexperienced .
Good day need advice Mercedes Benz GL63 X166 can x300m obdstar do dash via obd or it needs dual can filter to be installed as well
'If I helped, please click Thanks +Reputation.. !'
Hi, can you help me?
I have Skoda octavia III 9/2013 1.6TDI and i find good Mileage Adjustment Tool.
I have this type as a picture
5e0.920.861.e WJ3
I have obdatar x300 do full version. I had success on about 75% of the cars. Tried and worked on 2014 Pathfinder, caravans, journeys, tourag, Mercedes. It could not work on newer Ram with EVIC clusters, mostly 2014 and up
2016 citroen c4 picasso full lcd tft cluster killed with obd star
cluster totally dead and does not respond to diagnostic.
have you tried disconnecting battery as it might be stuck in boot mode ?
"Never confuse the size of your paycheck with the size of your talent"
battery removal did not help, eeprom corrupt... dash completely dead and no communication via diagnostic.
