Page 231 of 232 FirstFirst ... 131181221226227228229230231232 LastLast
Results 3,451 to 3,465 of 3467
  1. #3451
    Jan 2024
    I guess it depends which country you are in. Not sure the legalities in US, maybe it is different outside the US.
  2. #3452
    Apr 2016
    GT
    same problem, someone was able to do it, especially the 2018 cx5
  3. #3453
    Jan 2024
    Germany
    Hello, good morning/afternoon.
    not work
    Note: My writing is not completely correct. I use Google Translator.
  4. The Following User Says Thank You to Javierchr For This Useful Post:
    SAMKEY (1st February, 2024)
  5. #3454
    Nov 2020
    Dear colleagues,
    Be carefull with Renault Duster 2019 RH850 ,tried to adjust mileage with obdstar odomaster but after process completed the cluster became dark , RPM on 1 , no lights, speedometer not moving, no info on display, tried to write back recovery flash but nothing changed, i copied the backup flash from obdstar vci to laptop its RH850 (R7F701400) and try to write it back by programmer, i dont know if it would work out or not.
  6. #3455
    Jan 2024
    Germany
    Hello. thanks for the warning Nightdriver.
  7. #3456
    Jan 2024
    Germany
    I have studied these days and have looked for information.
  8. #3457
    Nov 2020
    Javierchr, in my case when reading it was ok the exact reading of mileage , thus i proceed ,but the problem appeared after writing , and its taking very long time more than 1 hour 15 min, dacia duster RH 850 was clearly stated in their supported list , i wrote to them but no reply till now, i think they are trying on us ,they dont do on real cars before claiming they are supporting particular model , fortunately my customer understands the situation and he is not worried bcz we have long term business relation and out of 4 cars he was doing day before ydy one failed, maybe one of our friends in dk is having a solution
  9. #3458
    Nov 2020
    After 3 days waiting for OBDSTAR reply, they simply answer me back that they dont support Renault Duster RH850 dash , its on their tool supported list !!!!!!!!!!!!
  10. #3459
    marina_rv's Avatar
    Ukraine
    Quote Originally Posted by Nightdriver View Post
    Dear colleagues,
    OBDSTAR - no all version supported
    C:\FLASHFILES ORIGINAL\MCU=RH850\
    |---RH850_V04.00_248B37438R_08 Jul 2019_12-24-23
    |---RH850_V06.00_248B34866R_04 May 2020_14-20-45
    |---RH850_V06.00_248B36896R_09 Jul 2020_18-43-46
    |---RH850_V06.00_248B37737R_04 May 2020_14-20-13
    |---RH850_V06.00_248B39132R_09 Jul 2020_18-43-59
    |---RH850_V06.00_285J22552R_04 May 2020_14-20-03
    |---RH850_V07.02_285J27035R_06 Nov 2017_12-56-42
    |---RH850_V07.02_285J27562R_06 Nov 2017_12-33-59
    |---RH850_V07.02_285J28502R_28 Mar 2018_15-09-33
    |---RH850_V07.02_285J29145R_28 Mar 2018_15-05-05
    |---RH850_V08.00_285J23620R_07 Dec 2018_10-08-09
    |---RH850_V08.00_285J25251R_07 Dec 2018_16-28-15
    |---RH850_V10.00_248B33225R_03 Jun 2021_16-38-03
    |---RH850_V10.00_248B35280R_03 Jun 2021_16-44-28
    `---RH850_V11.00_248B37097R_05 Apr 2022_09-45-53
    please press the little THANKS
  11. The Following 3 Users Say Thank You to marina_rv For This Useful Post:
    andkl2810 (9th February, 2024), SAMKEY (14th February, 2024)
  12. #3460
    Nov 2020
    Thanks for the info, so better in future to do with other tool, even it reads duster 2019 correctly,write with success , but i dont know what happened to cluster !!!!!1
  13. #3461
    Lithuania
    X300 DP Plus
    caddy 2016 ... dash OK
    DSG obd ..... OK
    peug 3008 2013
    BSI obd ... OK
    Dash need remove and do with eprom programmer
    Volvo
    v70 2010 .... no go, millage jumps back
    XC70 2010 .... not recognized
  14. #3462
    Aug 2019
    My first odo master experience:
    Octavia 13y 5E0920860D Nec35xx No
    Touareg 10y 7P6920880A No Read eprom on 4th atempt,but can not write,maybe need many atempts.
    Touareg done with Smelecom.
    Older vag cars with CDC work of course.
  15. #3463
    Nov 2020
    Hi, anyone tried to adjust mileage using odomaster for Renault Duster 2017 , cluster photo attached, thanks in advance
  16. #3464
    Aug 2015
    Does anyone have a x300 mini PSA?
    works on peugeot 308 t9 2018 bsi delphi?
  17. #3465
    ASCM's Avatar
    Oct 2018
    Did you solved the problem?
    Sent from my SM-A055F using Tapatalk
