Anybody tried Ford Fusion 2004?
Will be succesfull?
Will be succesfull?
Ford Fiesta 2009 EUR OK, 1min Job Done 100KM Difference
rtbdiagnostic (5th July, 2017)
rtbdiagnostic (6th July, 2017)
What's the difference between OBDSTAR X300M OBDII and OBDSTAR X100 Pro, which one is better for Mileage correction? Please, advice, I'm planning to buy one, but not sure. Also, where should I buy it to make sure is the best quality.
Thnks in advance
metalik (13th July, 2017)
hey test land rover discovery 4 - model 2010 . 1 min work parfect
Is same same for odo correction
Mondeo 2008 breaks communication
Now done using New Mondeo full colour option
I've just correct ODO of Mazda 3 AT 2015 (eepromt 93c76). It took 3-4minutes , OK
Tried a 2008 ML 350 W164 dash it reads mileage 100% after write removed the 5A dash fuse and reverted back to old mileage within 2 seconds
Ended up after several attempts fixing with digiprog by flashing dash breaking sync with the ezs and adapting the Assyst service history
Any advice as I am using the X-100 Pro not having much success so far .... hoping to be able to work on the new fiesta blue screen dash and the new ford ranger jeep grand cherokee as well as the range rover 2014 still need to test and report
'If I helped, please click Thanks +Reputation.. !'
rtbdiagnostic (18th July, 2017)
2012 astra no go,reads ok,cant change(security access failed),bcm with ep.95160.
Someone tried it on golf cart 7 with dash vdo year 2014 ??? Fails or works ???
In what year did not work? For the first models with vdo box does not work either? Is not a good tool then: s
