Tried a 2008 VW Transporter obdstar read the correct km with k-line vdo and after a couple min it says finish Success !! The dash km dissapear and then the original number come back on the dash . anyone give some advice please i tried all the vw variants and would only read with the k-line vdo .
Thos (13th November, 2017)
double post sorry
tried disconnecting battery but made no difference
thos
Discovery 4 2011 ok
Im doing any update on x100 and the Mercedes has only 3 cars- never change. Have I got copy of device?
Genuine tools including Abritus, Autotuner Master, Bosch Ford vcm2, smok UCDS FULL JTAG FULL pcm flash, IO terminal, UPA, Autel maxicom pro, MTX dpf, dtc, immo edc17 UCDS, and a little well maintained hairy box from china I play inside!
4.94 x100 fgtech kess ktm ktag mpps skp. And still collecting
I'm not sure...
but maybe they would have preferred you ask before putting a direct link ?
I'm not having a go far from it but you have set a group up between a lot of folk who use the forum.
I only use the equipment on a occasional basis if I'm stuck but its nice to see if people get problems and hear work arounds, normally I use enigma or upa etc.
I prefer to use the forum and not join groups so would hope that any problems ,or successes still appear on here.
just my 2 cents
