Zgemma 2s OpenAtv 5.2 Backup Image with Improved $ky Skin - Page 3
Page 3 of 22 FirstFirst 1234567813 ... LastLast
Results 31 to 45 of 324
  1. #31
    Jan 2013
    The Lake County
    I hope to give this a go later in the week. Only got my Zgemma 2s last week and am still learning (previous box was a DM500s with Commando image so didn't learn a lot). Does this image have any plugins installed (IPTV List Updater, MediaPortal, OpenWebif, TSmedia etc)?
  2. #32
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Quote Originally Posted by MelvisP View Post
    It has the following plugins installed; openwebif, autobouquetmaker, crossepg all the other plugins you mention aren't installed but are available from the plugins menu
  3. The Following User Says Thank You to martin035 For This Useful Post:
    MelvisP (10th November, 2015)
  4. #33
    Hi guys!!
    Thanks to martin.......I have been playing around with this image and I can confirm it works fine on my H1
    I had to delete the ABM's then reboot box to get no channels then I had to do the scan with my region and it worked a treat for my wanted area!!
  5. The Following User Says Thank You to toe471 For This Useful Post:
    martin035 (11th November, 2015)
  6. #34
    Jul 2013
    Sunderland
    I'm having an issue with using CrossEPG on my Zgemma Star S. I have it set to download Astra28.2 on OpenTV, it'll download a 2MB file (but hang on reading at 488KB and take about 5 minutes before ending, when I check the EPG I only have the freeview guide.
    I also have an Amiko Alien 2, which is setup the same in CrossEPG, it'll download a 14MB file and take just over a minute to complete.
    Both boxes have the latest OpenATV 5.1 image. Below is the log file from the Zgemma:
    12/11/2015 06:52:59 SIFTeam CrossEPG Downloader 0.8.1+gitrAUTOINC+7cff40b6c6 (c) 2009-2014 Sandro Cavazzoni (https://github.com/oe-alliance/e2openplugin-CrossEPG)
    12/11/2015 06:52:59 This software is distributed under the terms of the GNU Lesser General Public License v2.1
    12/11/2015 06:53:00 Interactive: OPEN cmd received
    12/11/2015 06:53:00 EPGDB opened (root=/media/hdd//crossepg)
    12/11/2015 06:53:00 Clearing old aliases...
    12/11/2015 06:53:00 Loading 'aliases.conf'...
    12/11/2015 06:53:00 Loaded 1 aliases
    12/11/2015 06:53:00 Adding new aliases...
    12/11/2015 06:53:00 Completed
    12/11/2015 06:53:00 Interactive: OK action sent
    12/11/2015 06:53:00 Interactive: DEMUXER cmd received
    12/11/2015 06:53:00 Interactive: FRONTEND cmd received
    12/11/2015 06:53:00 Interactive: DOWNLOAD cmd received
    12/11/2015 06:53:00 Started OpenTV events download
    12/11/2015 06:53:00 Reading dictionary '/usr/crossepg/providers/skyuk_astra2_28.2.dict' ...
    12/11/2015 06:53:00 Completed. Read 512 values
    12/11/2015 06:53:00 Reading channels...
    12/11/2015 06:53:10 Read 897 channels
    12/11/2015 06:53:10 Reading titles...
    12/11/2015 06:56:24 Maximum loop exceded
    12/11/2015 06:56:24 Read 561 KB
    12/11/2015 06:56:24 Parsing titles...
    12/11/2015 06:56:28 Titles parsed
    12/11/2015 06:56:28 Reading summaries...
    12/11/2015 07:02:14 Maximum loop exceded
    12/11/2015 07:02:14 Read 2.08 MB
    12/11/2015 07:02:14 Parsing summaries...
    12/11/2015 07:02:21 Summaries parsed
    12/11/2015 07:02:21 Ended OpenTV events download
    12/11/2015 07:02:21 Interactive: SAVE cmd received
    12/11/2015 07:02:22 Interactive: CLOSE cmd received
    12/11/2015 07:02:22 EPGDB closed
    12/11/2015 07:02:22 Interactive: OK action sent
    12/11/2015 07:02:22 Interactive: QUIT cmd received
    12/11/2015 07:02:58 SIFTeam CrossEPG DB Info 0.8.1+gitrAUTOINC+7cff40b6c6 (c) 2009-2014 Sandro Cavazzoni (https://github.com/oe-alliance/e2openplugin-CrossEPG)
    12/11/2015 07:02:58 This software is distributed under the terms of the GNU Lesser General Public License v2.1
    12/11/2015 07:02:58 EPGDB opened
    12/11/2015 07:02:59 Creation time: 12/11/2015 06:53
    12/11/2015 07:02:59 Last update time: 12/11/2015 07:02
    12/11/2015 07:02:59 Headers db size: 700 KB
    12/11/2015 07:02:59 Descriptors db size: 1.04 MB
    12/11/2015 07:02:59 Indexes db size: 141 KB
    12/11/2015 07:02:59 Aliases db size: 18 bytes
    12/11/2015 07:02:59 Total size: 1.88 MB
    12/11/2015 07:02:59 Channels count: 703
    12/11/2015 07:02:59 Events count: 19729
    12/11/2015 07:02:59 Hashes count: 12065
  7. #35
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Quote Originally Posted by gregthomas02 View Post
    Crossepg 0.8.1 doesn't work with Openatv5.1 and the Zgemma series.
    Would advise you flash my backup image onto your zgemma s as this has the correct working version of Crossepg install, as the zgemma s only has one tuner you will need to disable tuner B before doing any Autobouquetsmaker or Crossepg scan
  8. The Following User Says Thank You to martin035 For This Useful Post:
    gregthomas02 (12th November, 2015)
  9. #36
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Default Updated OpenAtv5.1 Backup Image 2S & H1 13/11
    New OpenAtv5.1 Backup Image added.
    • slyk HD Skin updated to v1.7
    • MUTV HD added to 'Sports' Folder
  10. #37
    Jan 2013
    The Lake County
    Quote Originally Posted by martin035 View Post
    Thanks Martin. I flashed this image this morning (before you updated it). Everything seems to be spot on so far. Is there a quick way for me to update the slyk HD skin to v1.7?
  11. #38
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Remove the skin via remove plugins, reboot, install the V1.7 skin via software manager-local extension installer, set skin to slyk HD via the skin set up menu.
    You'll have to search for the v1.7 skin as linking to another forum is against forum rules.
  12. The Following User Says Thank You to martin035 For This Useful Post:
    MelvisP (13th November, 2015)
  13. #39
    Feb 2012
    Love this image, and thanks so much for the help you have provided me, but my clock has disappeared from standby since the update is there anyway to get it back?
  14. #40
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Quote Originally Posted by MW35 View Post
    This happened to me when I did an OTA update a couple of weeks back, Openatv OTA updates can be quite flaky at times.
    Either reflash your Zgemma with either your own backup image, if you've made one or use mine, then wait a week for Openatv to fix the problem.
    Or try nightly OTA updates until Openatv fix the problem.
    Or search the internet for a fix.
    I updated my box and DK forum image this morning with no problems so it might have been a problem with the software released later today???
    This is why it's always best once you've set up your Zgemma IE skins, bouquets, settings, plugins ,picons and other important files you should make your own backup image. So if a OTA update does muck up its just a quick reflash.
  15. #41
    Feb 2012
    It was from the image on the front page of this post that I used, the one you posted the other day, that I have a problem with the time in standby.
  16. #42
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Lol, thought you meant you'd done a OTA update. Just checked mine and yes when you put the box into standby the clock go off, bring it out of standby the clock reappears.
    Edit: Fix: setup-usage&gui-display-display setting and scroll the 'brightness(standby)' one to the right.
  17. #43
    Jan 2013
    The Lake County
    I have this running now for a week and I am very impressed. Thanks Martin. I have even updated the skin to version 1.8...
  18. The Following User Says Thank You to MelvisP For This Useful Post:
    martin035 (21st November, 2015)
  19. #44
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Thanks for the kind words, I haven't updated the skin on the uploaded version as kiddac will be finalising his skin in the next week or so, so will just update the version when 'slky hd v2 final' is released.
  20. #45
    Default help line
    I must try and read the Forum rules
    Discussions about Servers, Providers, ~~~~~s,Nlines, Gift's etc will be edited or removed.
