Page 12 of 22 FirstFirst ... 27891011121314151617 ... LastLast
Results 166 to 180 of 324
  1. #166
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Default Openatv 5.2 News
    Did a Software update to my 5.2 image last night and the updated 'autobouquetsmaker 2.0+git1616' corrupted the firmware, ie broke software manager, softpanel manager, Openwebif interface & other things.
    So if using Openatv5.2 don't do any software updates at present until this bug is fixed.
    I tested my 5.1 image with an software update and there is no problems, updates and functions correctly a new Openatv5.1 backup image has been added to post #1
    This problem only effects Openatv5.2, Openatv 5.1 is safe to install and update.
  2. #167
    digicon's Avatar
    @martin035
    if you are trying to update any image that has been installed before the 8th march you will corrupt it, this has been pointed out over at ATV you need to do a new fresh clean image install with a release after the 8th march date.
    it's a little hard to do the German translate but they did warn they where trying to implement some form of full flash update feature which resulted in the corruption.
    I had a similar thing happen on my Solo4K i had to reflash with a later image which now has been resolved.
  3. The Following 3 Users Say Thank You to digicon For This Useful Post:
    happy_highlander (12th March, 2016), Johnner (12th March, 2016), martin035 (12th March, 2016)
  4. #168
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Thanx digicon for the info, but once the update knackered my Zgemma I tried a fresh install using a base image dated 11/3 all was good until I put the autobouquetmaker plugin on, then it corrupted the image.
    But I'll give it a few days and a couple of Google translation later and try again
  5. The Following User Says Thank You to martin035 For This Useful Post:
    digicon (12th March, 2016)
  6. #169
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Default Openatv 5.2 Rebuilt
    New OpenAtv5.2 Backup Image added.
    • Openatv 5.2 Rebuilt to fix bugs reported at post #162 & #166 Thanx to Digicon on how to fix the issue
    • Channel 5HD moved to All Channel Bouquet channel 171
    Both Openatv5.1 and Openatv5.2 updated, working and OTA update safe.
    If you have the Openatv 5.2 version dated before 14/3/2016 you will need to install this fresh image to overcome any problems.
  7. The Following 3 Users Say Thank You to martin035 For This Useful Post:
    digicon (15th March, 2016), satsmo (15th March, 2016), toe471 (15th March, 2016)
  8. #170
    Thanks for your work here martin its much appreciated buddy!!!
    I have a new Zgemma s2 landing in a couple of days as my H1 was faulty but not had time to get round to getting a new box!
    What do u recommend the most newish image for me to flash of yours with ABM on also matey which wont be buggy? Don't want to flash one then get it set up then its wrong version
    Cheers!!
  9. The Following User Says Thank You to toe471 For This Useful Post:
    martin035 (15th March, 2016)
  10. #171
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    @toe471
    I'm using 5.2 since the 23rd of Feb, the only issues I've had are the volume problem and update problem described earlier, now fixed and no issues for 48HR+. Before that I was using 5.1 and again had issues with updates breaking things, then getting fixed.
    IMHO go with 5.2 it will most probably have more long term support.
  11. The Following User Says Thank You to martin035 For This Useful Post:
  12. #172
    Nice one Dude!!
    So im getting the 5.2 beta image?...... In your description on setting up, im sure I read last time that we need to put picons onto the sd card?
    PS
    Are there any updated picons knocking around??
  13. The Following User Says Thank You to toe471 For This Useful Post:
  14. #173
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Quote Originally Posted by toe471 View Post
    Beta it is but after some teething problems it's quite stable now.
    Nope, the picons are built into the image and as their basic picons they take up little room on the internal flash.
    are there any updated picons knocking around??
    The picons cover most channels except new channels ie showcase+3 or temp channels $ky robots. If you want different picons then delete the picon off the internal flash and install new picons from the download plugin section.
  15. The Following User Says Thank You to martin035 For This Useful Post:
  16. #174
    Had this image running now for a few days and it seems good, only problem now tho martin is that im scared to do an update just incase it buggers anything up?
  17. #175
    happy_highlander's Avatar
    Aug 2010
    Why bother updating. Don't fix what's not broke.
    I usually do a clean install twice a year unless there are any major changes or if there's any noticable bugs and even then I prefer a clean install rather than a bits and pieces update.
  18. The Following 2 Users Say Thank You to happy_highlander For This Useful Post:
    maca (20th March, 2016), martin035 (20th March, 2016)
  19. #176
    maca's Avatar
    Feb 2009
    liverpool
    Same here H although there are times when you just think hmmm wonder what would happen if i did this
  20. The Following 2 Users Say Thank You to maca For This Useful Post:
    happy_highlander (20th March, 2016), martin035 (20th March, 2016)
  21. #177
    Aug 2010
    Quote Originally Posted by maca View Post
    I have lots of them moments thats how I find out how to fix things haha and I very rarely think to make a backup first press buttons then engage brain is my prefered method
  22. The Following 2 Users Say Thank You to happy_highlander For This Useful Post:
    maca (20th March, 2016), martin035 (21st March, 2016)
  23. #178
    digicon's Avatar
    A software update now and again should not create any problems after all most updates are for plugins and maybe drivers etc.. that have been updated such as ABM for channel changes or amendments
  24. The Following User Says Thank You to digicon For This Useful Post:
  25. #179
    Dec 2015
    Got a problem that's only started recently. My crossepg is set to update 7am it updates just fine, but if turn the box off at the wall & back on again it forgets all that's just been updated in the TV guide.
  26. #180
    Aug 2010
    Change the cross epg setting to automatically reload on boot
  27. The Following User Says Thank You to happy_highlander For This Useful Post:
    madness85 (21st March, 2016)
