Page 17 of 22 FirstFirst ... 71213141516171819202122 LastLast
Results 241 to 255 of 324
  1. #241
    Mar 2016
    Does anybody know if there is a way on the sports interactive channels to choose a channel when it gives you more than one option to watch.
    Many thanks Matt...
  2. #242
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Quote Originally Posted by Mattk1975 View Post
    Many thanks Matt...
    @Mattk1975 it might be best if you make your own thread as I don't know the answer and other forum members might not see your question here.
  3. #243
    Alrite martin!!!
    Im gonna stick this new 5.3 image on in the next few days and try it? just wanted to ask......Is it ok to do an update soon as I have put the 5.3 on? Dont want to mess anything up if its not a good idea you see
  4. #244
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    @toe471 the image is OTA safe but do what I advise all to do, install the backup image, set it up for your region, put you magic on and get the box to a stage where you're happy with it. Then do your own backup image, so if a future update or user error breaks the firmware it's just a software restore and your back to where you started before the update or finger problems.
  5. The Following User Says Thank You to martin035 For This Useful Post:
    toe471 (26th April, 2016)
  6. #245
    Hadron's Avatar
    Nov 2012
    E. London
    Put this image on my new H2 a couple of days ago. Set up the sat side with no problems. Set up the cable side yesterday. Scanned & set up autobouquets OK.
    My problem is...how do I get back to watch the satellite channels? It's probably staring me in the face, but I've been trying all morning & can't see an obvious way to switch between cable & sat.
    I've gone into the menu & selected tuner A, but it just goes back to tuner B again.
    btw...many thanks martin035 for the image. I first tried to set up the box using a basic OpenATV image & setting it up myself, but gave up when I found your image where you had done all the hard work for us!
  7. #246
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    @Hadron, I've never setup the box for cable but I know a man who has, give happy_highlander a PM I'm sure he'll help you out.
    Edit: Or try maca's advice below.
    And remember to follow the advice in post #144 to setup the EPG for cable.
  8. The Following 2 Users Say Thank You to martin035 For This Useful Post:
    Hadron (1st May, 2016), happy_highlander (30th April, 2016)
  9. #247
    maca's Avatar
    Feb 2009
    liverpool
    In favourites keep scrolling down the page the vermin list should be there mate
  10. The Following 2 Users Say Thank You to maca For This Useful Post:
    Hadron (1st May, 2016), martin035 (30th April, 2016)
  11. #248
    happy_highlander's Avatar
    Aug 2010
    If you want vermin first so that you have easier access to the hd. Change the provider order in autobouquet setup so that vm is on top.
  12. The Following 2 Users Say Thank You to happy_highlander For This Useful Post:
    Hadron (1st May, 2016), martin035 (1st May, 2016)
  13. #249
    Hadron's Avatar
    Nov 2012
    E. London
    Quote Originally Posted by maca View Post
    Quote Originally Posted by happy_highlander View Post
    I think I know what I did wrong.
    Because the bouquets were already set up for Sky in the image, after I scanned in my cable channels I ran auto bouquet maker to just set up the cable channels (I unselected Sky UK in the providers menu). It looks like doing this erased the previous Sky bouquets. That's why I could only see VM bouquets when I pressed the FAV button.
    I was assuming that there would be 2 seperate bouquets that I could swap between by pressing a button on the remote.
    I have now run ABM again, only this time selecting VM and Sky UK in the providers menu.
    I have VM set up first in the Providers order.
    Next step is to get the EPG working for VM using happy_highlander's guide.
    Thanks for your posts.
  14. The Following 2 Users Say Thank You to Hadron For This Useful Post:
    happy_highlander (1st May, 2016), maca (1st May, 2016)
  15. #250
    digicon's Avatar
    EPG Refresh Guide thanks to Abu Baniaz for the pdf Guide
  16. The Following User Says Thank You to digicon For This Useful Post:
  17. #251
    Mar 2016
    Little help please?, i want to change the background for when the box is rebooting i've tried the oxorion boot logo program and it changes everything except the afore mentioned reboot background.
  18. #252
    Aug 2010
    You'll have to be more specific about what image you want to change. There are the different images on boot first to display is splash image and can't be changed with a boot logo program. Second to display is boot image and third is background
  19. #253
    Mar 2016
    The one i want to change is the minions background that comes up when the box is rebooting , every other build i have used it can be changed with the xorion program but for some reason it wont on this
  20. #254
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Quote Originally Posted by randomry View Post
    To change the reboot image.
    1. Convert,resize and rename your new reboot image to a 1280 x 720 .PNG image using paint on a PC
    2. FTP this new image to your Zgemma to the following location /usr/share/enigma2/slyk-1-hd/mybackgrounds/
    3. Reboot Zgemma
  21. The Following 2 Users Say Thank You to martin035 For This Useful Post:
    Hadron (6th May, 2016), randomry (7th May, 2016)
  22. #255
    Mar 2016
    Quote Originally Posted by martin035 View Post
    3. Reboot Zgemma
    Good stuff, will have a crack later, cheers mate
