No, just flash the box.
Thought would pop my question here away from the openbox (cant see the delete thread option in there) , anyway got the link to the 5.3 image (thx) and put on a usb ready , do i have to take of the grey open atv firmware that came pre installed on the box first ? (star s) cheers ... zgemma noob
martin035 (9th May, 2016), PutTheFootieOn (9th May, 2016)
Put the image on on USB drive, stick it in the back usb port, switch box on, box will say boot then USB then if it doesn't go to flash hit hit the power button on front of box, it should now start flashing the image.
@Putthefootieon, ensure you unzip the downloaded file then place the 'zgemma' folder on your USB stick drive
Thats how i did it yeh ,
you know this 5.3 image is that the blue sly skin etc, or just a update of open atv that is already on the box as looking in settings i manged to detect/see 5.3 in a setting folder dont know if its already on, or if that is something else, im trying (goal) is getting it looking like the blue epg style interface skin .. thx for help .. cheers
@putthefootieon, it's the blue sky like skin with EPG and channel maker, pictures available at post 1.
PutTheFootieOn (10th May, 2016)
Finally Got it going after thought i'd bricked the box constant loading on the open atv after doing a factory reset, but getting that sorted then the 5.3 software on straight after cut out a lot of the work that's for sure (Nice one) i set the epg auto bouquet thing to my region but itv is yorkshire anyway of fixing
Cheers ,
Hi. thx , Two things
will i have to rescan channels now as just set it to merseyside custom area then restarted box but still same Yorkshire when checked on the quick remote pull down , Also i noticed when i press epg to see the full screen epg as in choosing bouquet or section i.e entertainment , it was pretty much blank only had one or two stations max that had any epg in atall ..(epg is set to usb dongle at front panel) i was even up at 4.30 am when it updated the light on it was flashing
i did fully power down the box from wall 10 minutes or so after that had completed dont know if thats affected the epg as did seem fine till starting back up this morning
PutTheFootieOn (11th May, 2016)
Or you can setup a power timer to put the box into standby for you at your desired time for the update, that's the way my H.2H is setup... autobouquet scan at 03.00am then powertimer into standby at 03.15 for 5 mintue EPG refresh scan for Vrigin Media and wakeup again at 03.30 for EPG-Importer scan for SKY.
