madness85 (12th May, 2016)
Thought I'd ask here rather than create a new thread.
Is there any IPTV/KODI ability with this box and image? I've tried to use kodi direct and castaway but no streams will load and the waiting time is horrendous. Even an IPTV plugin that I could use with a provider would be decent to stream foreign channels. Thanks!
IMHO and this is how I do it;
Zgemma series either orginal or H = Best for Sat/Cable receiver
Amazon Fire Stick with Kodi Sideways installed = Best for IPTV
If you want to try using your Zgemma then give this member a PM he made a load of custom Addons for Kodi direct
Blacky1973 http://www.digital-kaos.co.uk/forums...867-blacky1973
Is it possible to get the picons/station icons that run down the left side and come up in some epg settings in full colour and not transparent , cheers
I can't update this image anymore, due to me having a H.2s instead of a 2s, there's 2 ways to do this;
Method 1 - Picons from the OpenAtv's Repo
1. FTP (Using Filezilla) to zgemma's picon folder location /usr/share/enigma2/picon and delete that folder
2. Install a new picon pack from the plugins menu
Method 2 - MK's Colourful Picons
1. Download the picon.zip and unzip the folder
https://www.dropbox.com/s/j60te4juaw...picon.zip?dl=0
2. Weed through the picon folder and remove all 'none working' HD picons, Incorrect referenced picons ie Animalplnt as the correct one is Animalplanet etc, Vmedia picons and picons for any bouquets you don't use ie if you dont use the 'Adult channels' remove all the 'named adult picons'. This will reduce the size of the picon folder, otherwise it will fill up your zgemma's internal flash with unwanted picons, you can place them on the Zgemma Hdd but it will slow the box down.
3. FTP (Using Filezilla)to zgemma's picon folder location /usr/share/enigma2/picon and delete all the files in that folder
4. FTP over the picons in your already weed out picon folder to picon folder on the zgemma /usr/share/enigma2/picon
5. reboot
PutTheFootieOn (11th June, 2016)
Would this image be ok on the zgemma star s (single tuner) ?
Thanks!
hi martin
hope your are ok pal
just a quick one...
im having problems with my zgemma h2 box..
i was missing some channels so i did a rescan thro autoboucquetmaker
and now..
i cant get slysports 2 hd.. at all!
and in some..if HD works..SD wont work and vice versa
if i restore an image from my previous backup then sky sports 2 hd comes back but then some are still missing!!
and if i run auto bouquetmaker then i get HD and SD probelm
can you help please?
neilesh
Fine thanx, day off, just watched 1 of 3 Euro matches so life is good.
Ok, as you talking about HD I take it you have a Satellite and Cable feed to the h2? I'm very limited with the help I can give on Cable issues as I don't use cable just the satellite, the only advice I can give is to;
1. Update the Zgemma software via Menu-Setup-Software management-Software update once updates found press green to update
2. Reboot the h2
3. Run Autobouquetsmaker Scan again and see what you get.
If problems persist, advise posting in the Cable sub forum as more cable users will see it there and be able to help.
hi there i done all as you advised just stuck on one place cant add cccam.cfg done google and tried with filezila as well but no hope so can you plz tell me how i can add that.
Thansk
hi martin
i think you have done 110% work for this image but i think ay be i am doing something wrong that i cant add my Cccam.cfg file in it i tried with filezila and
after that i need to press blue button to activate but no option is coming there for activate and its no working as well so could you please help me here step by step because am not very expert with this box .it will be really appreciated .
Jadi720, you're doing nothing wrong with the image but unfortunately as stated in post #1 it's against forum rules to discuss lines or cams, hopefully you've received a PM from middots as that's all that can be said on an open forum.
satsmo (15th June, 2016)
not getting the usb display on box on zgemma
