Page 20 of 22 FirstFirst ... 101516171819202122 LastLast
Results 286 to 300 of 324
  1. #286
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Quote Originally Posted by jon50 View Post
    not getting the usb display on box on zgemma
    Ensure you unzip the downloaded file, then place the 'zgemma' folder on to your USB stick drive, place USB stick drive into rear USB port then switch on. If you don't get the 'USB' on front panel then try again with a different USB stick, as the Zgemma can be fussy with some makes of USB sticks.
  2. #287
    Feb 2012
    Thanks for taking the time doing the image, but I have a motor setup, and sometimes when I'm on different satellites for example 23e or 1w the picture goes off, I look at my cam settings on my zgemma and it says no soft cam selected it does this quite often, I change it back to C***** 2.3.0 its ok for a bit but then it goes off again, I got to keep putting the cam back, is there any fix? Seems ok on 28.2 and 19e but not the others.
  3. #288
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    @MW35 I only use a static setup pointing @28.2e so haven't experienced this issue, perhaps try a difference version instead of 2.3.0 or try a backup image that uses openvix instead of openatv, however, as were talking about cams I don't think the mods would be very happy discussing it further, so think it's best left there.
  4. #289
    digicon's Avatar
    Quote Originally Posted by MW35 View Post
    Thanks for taking the time doing the image, but I have a motor setup, and sometimes when I'm on different satellites for example 23e or 1w the picture goes off, I look at my cam settings on my zgemma and it says no soft cam selected it does this quite often, I change it back to 2.3.0 its ok for a bit but then it goes off again, I got to keep putting the cam back, is there any fix? Seems ok on 28.2 and 19e but not the others.
    Change the Python script starter to init.d in the softcam section should sort it.
  5. The Following User Says Thank You to digicon For This Useful Post:
    martin035 (30th June, 2016)
  6. #290
    Feb 2012
    Thank you for the reply, but how do I do that?
  7. #291
    happy_highlander's Avatar
    Aug 2010
    Blue button>softcam (left panel)>softcam panel setup (right hand panel) then change Start Mode from python to init.d
    Sent from my SM-G935F using Tapatalk
  8. The Following User Says Thank You to happy_highlander For This Useful Post:
    digicon (3rd July, 2016)
  9. #292
    Feb 2012
    Thanks for that but unfortunately the problem is still there,
  10. #293
    Mar 2016
    Where do I find the folder to put new picons on please. Since Setanta has changed to Eir sports there isn't a picon at the min.
    Many thanks matt.
  11. The Following User Says Thank You to Mattk1975 For This Useful Post:
    martin035 (7th July, 2016)
  12. #294
    Mar 2016
    Found it mate, thanks anyway..
  13. The Following User Says Thank You to Mattk1975 For This Useful Post:
  14. #295
    Apr 2011
    manchester
    How can I rearrange channels on Gemma 2s
  15. #296
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Quote Originally Posted by damusikman View Post
    There's 2 ways to do this;
    Method 1
    On the remote press 'Fav' then find the channel you want to move and press 'menu' and 'enable move mode' then press 'ok' on the channel you want to move and use the up/down arrows to move the channel to it's new place then press 'ok' again.
    Method 2 requires a PC
    Open the Openwebif portal on your web browser, on the lower left side click on 'Bouqueteditor' then on the right just drag either the bouquets or channels to there new place.
  16. #297
    Hi Martin035
    Finally got around to havng a go at putting your 5.3 image on my zgemma!
    I put over the 5.3 image but was in 2 minds whether to update to see if everythng was stable after...................YES it worked and booted up fine and and the ABM seemed good!!!
    What i wanted to ask was how do we go about updating the picons on the image that is flashed onto box?? Also how do i put the colour type picons on instead of the trans ones as you cant really see the original ones on now?
  17. #298
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Quote Originally Posted by toe471 View Post
    The picons in the Dropbox download ain't the newest, the colourful picons don't get updated regularly,
    1. Download the picon.zip and unzip the folder
    https://www.dropbox.com/s/5qnyczheq6igoyb/picon.zip?dl=0
    2. Weed through the picon folder and remove all 'none working' HD picons, Incorrect referenced picons ie Animalplnt as the correct one is Animalplanet etc, Vmedia picons and picons for any bouquets you don't use ie if you dont use the 'Adult channels' remove all the 'named adult picons'. This will reduce the size of the picon folder, otherwise it will fill up your zgemma's internal flash with unwanted picons.
    3. FTP to zgemma's picon folder location /usr/share/enigma2/picon and delete all the files in that folder
    4. FTP over the picons in your already weed out picon folder to picon folder on the zgemma /usr/share/enigma2/picon
    5. reboot
  18. The Following User Says Thank You to martin035 For This Useful Post:
    toe471 (8th July, 2016)
  19. #299
    Theres no link there martin???
  20. #300
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Fixed, just copy and paste the link
  21. The Following User Says Thank You to martin035 For This Useful Post:
    toe471 (11th July, 2016)
