Muss Chanage SN to work full Yes?
Wysłane z mojego C6603 przy użyciu Tapatalka
Key learning Bmw X6................................Key learning Opel vectra c....................Key learning Fiat Stilo 2001
Fvdi 2014 v10.3......................................v5.8 read pin auto detect.....................v5.1 v5.4 can not read bcm
Read Cas ista-p45...................................learning spare keys..............................can prepare key from dump
Failed............................................ ........Key learning successfully.................can add spare key
damage cas............................................... .................................................. ..Key learning successfully
Can not duet bmw x6
Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
This is support for colleagues able to rely on what the fvdi device can do or can not
If that does not work, it would create damage to the car
If I did the damage, does not have other colleagues
and not for other things
but you already know that
totoo if you write this things - FVDI V2014 is not good , many bugs , please buy fvdi 2.
please give my money back, if you sell shit.
any solution to this fault please...only porsche give this error other soft works...error.JPG
Totoo has gone fishing ... trying to get another 'engineer' to come on and answer your problems .....
Meantime apparently there has been an update ..
FVDI 2 2017-3-29
V3.8 released
1. Quick Loader V3.2
* Bug fix for loading HDS
2. OBD Terminator
* Bug fix for All keys lost of Audi A6, A7, A8, VW Touareg
and
2017-3-31 V3.9 released:
1. Quick Loader V3.3;
1.1 Bug fix for loading HDS (No odometer rewrite menu);
1.2 Add support for IDS for Mazda V104;
2. Install software;
2.1 Update FTDI driver to 2.12.26;
3. Update software;
3.1 Update user interface;
and
2017-4-1 V3.10 released:
1. Quick Loader V3.4;
1.1 Add support for TIS for Toyota V12.00.124(Please contact with technical support for registration);
2. OBD Terminator software;
2.1 Bug fix for All keys lost of Audi A6, A7, A8, VW Touareg(Support original key);
3. Update software;
3.1 Update user interface. Add downloading remain time;
Hi all!
I have an FVDI with very irritating problem. Cannot connect to any VAG convenience module over Kline.
-1C0 959 799 F
-1J0 959 799 AH
-6Q0 959 433
in car&on table same result, it says: Unit not responding...
What do i need to do?
After replacing the L9637D and ADG1406BRUZ and K6 MOS relay will work?
Someone has experience with this "bug" ? (sry my english)
Attachment 440154Attachment 440155Attachment 440157
any chance to solve this without changing os?all 17 softweres works except porsche.............
