Page 107 of 182 FirstFirst ... 75797102103104105106107108109110111112117157 ... LastLast
Results 1,591 to 1,605 of 2730
  1. #1591
    micromax's Avatar
    South Poland
    Quote Originally Posted by werner5395 View Post
    Hello have Problem with my FVDI Hardware- Can-line no work can no make anyone car with can-line. K-Line works without Problems . this Problem i have now 3 weeks bevor Can-line perfekt. i have change two chips: L9637D and ADG1406BRUZ
    but no work
    find my post about modification.
  2. #1592
    tiguan's Avatar
    Default Dash login Code Error,
    From a VW Touran 2010, I want to learn a new key
    FVDI can not read the DASH software for login code, giving this error.
    [SW version "08.50.00 24VK354608HL'. Pleas use dump tool for this version]
    What should I do to get this login code, Tool i need to get the dump
    Thank you
  3. #1593
    tiguan's Avatar
  4. #1594
    Kocta's Avatar
    Mar 2017
    Garage in the Czech Republic
    Zkuste verzi 18.
  5. #1595
    HeXeN's Avatar
    Mar 2015
    Alfa 147 BSI Marelli read by obd OK
    FVDI 2014
  6. The Following User Says Thank You to HeXeN For This Useful Post:
    p1et (10th September, 2017)
  7. #1596
    vsanyi's Avatar
    Aug 2012
    Astra G Z14XEP read pin Ok. Program key Ok. Fvdi2014
  8. The Following User Says Thank You to vsanyi For This Useful Post:
    maybach_ (25th August, 2017)
  9. #1597
    Duracell2's Avatar
    Apr 2017
    Opel ASTRA H, 2008, Z17DTR
    Read PIN : NOT OK
    Tool: FVDI 2014
    Software versions: both tried
    Me to the customer: don't worry Sir, I have veeeeeery good tool for reading PIN from ECU for Astra H.
    But then: Hehehe...
    Seems FVDI reads PIN for Z17DTL and Z17DTH engines (EDC16 ECU), but not for Z17DTR engines (Denso ECU)
  10. The Following User Says Thank You to Duracell2 For This Useful Post:
  11. #1598
    Oct 2015
    try to read CarPass From info display on astra h
  12. #1599
    Duracell2's Avatar
    Apr 2017
    Quote Originally Posted by mircea13 View Post
    have tried, but not possible
  13. #1600
    Feb 2017
    UK
    FVDI 2014 Program key in Citroen C5 2009 Diesel
  14. #1601
    Jan1980's Avatar
    Nov 2014
    Pin reading and reset ECU Opel Corsa C 1.0 on bench, engine 10XEP
    ECU is newer version 7.6.1 !! Not 1.5.5 !!
    Connection diagram from carprog manual used with relay. Carprog did not work !
    FVDI Version old 2014
    Opel Software 5.8
    Pin reading: OK (3 seconds)
    Reset ecu: OK
    Important, newer Opel evrsion on FVDI does not work in this case. You have to use old Opel 5.8 software !!
  15. #1602
    Duracell2's Avatar
    Apr 2017
    Quote Originally Posted by Jan1980 View Post
    what a surprise
    Please hit the rep & thank buttons if this post was helpful!!!!
  16. #1603
    Jan1980's Avatar
    Nov 2014
    Quote Originally Posted by Duracell2 View Post
    what a surprise
    LOOOOOOOOOOOOL....yes, i know
  17. #1604
    doctore's Avatar
    Nov 2015
    Colorado Denver
    Treads is only for FVDI technical support
    Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
  18. #1605
    Nov 2015
    can fvdi adapt(personalize) etc... a virgin Mercedes ecu successfully<br>
