Page 110 of 183 FirstFirst ... 1060100105106107108109110111112113114115120160 ... LastLast
Results 1,636 to 1,650 of 2733
  1. #1636
    Mar 2013
    Europe
    CANT DO!
    The FU**ING FVDI cant learn Dash on W211 2007
  2. #1637
    Oct 2017
    guys i need help with my fvdi 2014 f00204 id doesnt work any i try fwdownloader i hope to not destroy it
  3. #1638
    doctore's Avatar
    Nov 2015
    Colorado Denver
    Quote Originally Posted by angelosk View Post
    Go slowly , what a problem you have
    Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
  4. The Following User Says Thank You to doctore For This Useful Post:
    angelosk (13th October, 2017)
  5. #1639
    Oct 2017
    hahaha ok actually i received the fvdi didnt do anything on my car just see id and something like that i try fwdownloader but nothing i dont know if i change fvdi id or not
    i have the fwdownloader and the generator if is help
  6. #1640
    doctore's Avatar
    Nov 2015
    Colorado Denver
    fwdownloader its not for 2014 will demage your hardwer only for 2015 -2016 fly fvdi update online
    tr use your fvdi with original softwer and see on another car if will work if not send him back for replace
  7. The Following User Says Thank You to doctore For This Useful Post:
    angelosk (14th October, 2017)
  8. #1641
    May 2016
    Hello, im just buy FVDI 2015 install from disk 6.3 version and drivers, fwdownloader say that i have last firmware, but in programm im always have error FVDi not calibrate, im try different windows, different ftdi drivers, saler try reinstall over teamviwer and tell my send back, but in fwdownloader have option offline firmware install, where i can take two firmware??? Cose send back it very long story. Thx before for any helping.
  9. #1642
    Sep 2010
    fvdi corect milage on fiat punto 2004 ok and all lost key xsara picasso OK.
  10. #1643
    Oct 2015
    fvdi clone of clone recalibrate milage on caddy 2006 ok. vag loader v21
  11. #1644
    wissamshaat's Avatar
    Oct 2017
    france
    fvdi2
    audi a3 2004 2.0tdi recalibration dash
    done in 1 sec
  12. The Following User Says Thank You to wissamshaat For This Useful Post:
    motorsport (1st November, 2017)
  13. #1645
    Oct 2015
    fvdi clone of clone erase crash data on golf 5 vw8 airbag controller . read and write eeprom on obd ok with vag loader v21 . cleared crash from dump manually.
  14. #1646
    kronk92's Avatar
    Sep 2016
    France, paris
    Hi guys did someone already have this problem : i try to launch transponder maker for example in fiat software and it close the software immediatly
  15. #1647
    Quote Originally Posted by kronk92 View Post
    delete file tag.prg is located in program files\arbitrus folder
  16. The Following 2 Users Say Thank You to fifii69 For This Useful Post:
    buntbart (25th May, 2019), kronk92 (2nd November, 2017)
  17. #1648
    kronk92's Avatar
    Sep 2016
    France, paris
    Quote Originally Posted by fifii69 View Post
    thank you very much it works now
  18. #1649
    Nov 2012
    I bought Fvdi 2015 today .
    It is original Flyobd.
    But, in the CD that came with the software , the FWloader it is corrupted file. I tried even running the thing from the cd.
    Can anibody help here ?
    It is the real thing. I have serial number and everithing.
    Somebody help please.
    So now I have the Fwloader, it says that is connecting to server OK but cannot retrieve information.
    Any Ideea Anibody ?
  19. #1650
    Sep 2012
    Cuba
    Default BCM2 FLY OBD Terminator
    Estimados señores de digital-kaos.co.uk
    Acabo de comprar FVDI2 VAG.
    http://www.obd2tool.com/goods-5182-2...+Software.html
    Pero tengo dudas con la función de las teclas BCM2 a FLY OBD Terminator
    Para poder agregar una nueva clave en un Audi A4 2014 ( BCM2 ) , es necesario leer el BCM2 por medio de un programador independiente del FVDI, por ejemplo Orange5.
    ¿El FVDI2 tiene la posibilidad de leer el BCM2 y de esa lectura para programar la nueva clave?
    En este ejemplo en particular, el automóvil tiene una llave operada.
    En los tutoriales y guías que lo vieron, siempre dicen leer BCM2a través de Orange 5 y luego cargar esa lectura en FLY OBD Terminator y finalizar el proceso.
    Serían tan amables de darme una respuesta.
    Gracias por tu atención
