Page 111 of 183 FirstFirst ... 1161101106107108109110111112113114115116121161 ... LastLast
Results 1,651 to 1,665 of 2732
  1. #1651
    Jan1980's Avatar
    Nov 2014
    Fly FVDI 2014.
    Opel Corsa C 2002 1.7 diesel.
    Pin read: Ok
    Reset and teach in ECU: Ok
    Reset and teach in immobilizer: Ok
    Prepare PCF7935 to ID40 transponder with FVDI and genuine abrites tagtool: Ok, works fine!!! - BTW, genuine AVDI with Abrites Protag ID40 precoding was NOT WORKING !!! :-(
    Key teach in on this corsa: Ok
    BCM reset: not working !
    Citroen C5
    Key teach in with knowned PIN: Ok.
  2. #1652
    jodge's Avatar
    Mar 2017
    Quote Originally Posted by kronk92 View Post
    Hi guys did someone already have this problem : i try to launch transponder maker for example in fiat software and it close the software immediatly
    Fresh install 2014 FVDI and the same problem. When i try to run the transponder maker under any model the prog is crashing. And and didn't found any tag.prg file
    any idea?
    thx
  3. #1653
    kronk92's Avatar
    Sep 2016
    France, paris
    you have it in folder common > tag
  4. The Following User Says Thank You to kronk92 For This Useful Post:
    jodge (14th November, 2017)
  5. #1654
    wissamshaat's Avatar
    Oct 2017
    france
    new fvdi2 now everytime you open it it do a frimware update
    for every thing you do
    so it takes time
    bad update
  6. #1655
    Warning you must update your FLY Terminator or it will get locked
  7. #1656
    Feb 2017
    UK
    Hi can somebody face up with this problem. I bought FVDI 2014 some time ago and Key Tag Tool don't work, other function are OK drivers installed for main unit just not sure if the key tag has separate drivers as showing that programmer it can not be found. Please help
    Video - https://www.dropbox.com/s/tgm8ulp9sz...0TAG2.mp4?dl=0
  8. #1657
    koolstuff's Avatar
    Nov 2015
    Dakar (Senegal)
    My FVDI 2 two devices PSA and Renault are blocked and they say i must send back to repair, what a joke!! Why did they block all the device around the world? This is such a mess....
  9. #1658
    Dec 2016
    Espaņa
    Hi, Can fvdi2014 make immo bypass by obd for Golf 6 or all key lost key programming by obd?
  10. #1659
    auto techniek's Avatar
    Mar 2017
    Does the function Kia/Hyundai Pin code reading works wel with Fvdi 2014 ?
  11. #1660
    Mar 2013
    Europe
    Anyone know
    ford transit 2014 injector coding work?
  12. #1661
    Dec 2015
    Rafah, Palestine
    Not for all .
    For some desel motors yes.
    The only car i can read pin for is 2009 hyundai tuscon
    A freind of mine manage to read pins from 2012 touscon desel motor too
  13. The Following User Says Thank You to just4upal For This Useful Post:
    auto techniek (20th November, 2017)
  14. #1662
    Dec 2016
    Espaņa
    Can fvdi2014 with immotool programm Golf V all key lost including 2007+ via obd?
  15. #1663
    Jan 2017
    hello
    i have problem with clone FVDI - this is FVDI-2015-F18888 (full version 18 mark)
    i have VAG version v18 and v24 (strange)
    i need to make CP 1 generation from auxiliary heating (i have dump eeprom from AUX HEATING)
    in VAG v18 it does'nt work (EXS-Kessy with Algo 1 not working, Algo 2 also - wait wait wait and nothing...)
    in VAG V24 the program try to connect but in while is "not responding" and program close
    is this possible to make it with this clone?
  16. #1664
    AndyCZ's Avatar
    Jan 2014
    EU
    Quote Originally Posted by TukoSalamanca View Post
    Yes. Without any problem.
    If I helped you know what to do..
  17. The Following User Says Thank You to AndyCZ For This Useful Post:
    TukoSalamanca (24th November, 2017)
  18. #1665
    Feb 2017
    UK
    I thought this thread is about technical support, discussion long for 111pages but nobody can even answer for my problem with key tag adapter very disappointed.
