Page 115 of 183 FirstFirst ... 1565105110111112113114115116117118119120125165 ... LastLast
Results 1,711 to 1,725 of 2732
  1. #1711
    west mids, uk
    There is not a tool on the market that can read the pincode from this car, if was petrol engine then will work, need to get code from dealers or read TMS in immo box around IGN lock.
    DK- The Bogs Dollocks!!!
    NEVER SAY IT CANT BE DONE!!
    The thanks button works wonders!!
    DONT SEND ME PM'S ASKING FOR OTHER MEMBERS WORK OR PASSWORDS
  2. #1712
    Feb 2011
    Hi All,
    van egy új FVDI2015.
    Passat 2004 Dash olvasás írjon km ok.EDC15 nincs csatlakoztatva.
    Polo 2003 ugyanaz a probléma.A X-eszköz problémamentes.
    5 nap elteltével az eszköz zárolva, deaktiválva van. FW letöltő ...... conect serwer OK ....
    Információk lekérése a serwerről ..... sikertelen.
    Az engedély frissítése nem működik.
    Install 7.0 FVDI ,and problem solved.
  3. #1713
    Would like to buy the FVDI for this one sole function, repair DEF error on VAG cluster by OBD. Tried to do a search but DEF is a 3 letter word which doesn't produce any search results. To anybody that own this tool could you answer this question and tell me which version they have, would greatly appreciate it.
  4. #1714
    Kocta's Avatar
    Mar 2017
    Garage in the Czech Republic
    Fvdi 2014 Ok
    Press Thanks and Reputation
  5. The Following User Says Thank You to Kocta For This Useful Post:
    keysmith (9th January, 2018)
  6. #1715
    Sep 2013
    Car: Vw Transporter t5
    year: 2008 2.5 EDC 16
    Lost key
    FVDI 2015 done pin and key programing .Orginal vag dasch can ver.5.30.04 from Germany can;t connect to EDC16.
    Not Bad
  7. #1716
    auto techniek's Avatar
    Mar 2017
    On bench or by OBD?
    Quote Originally Posted by holbi1 View Post
    Lost key
    Not Bad
  8. #1717
    Are there any issues in installing the FLY FVDI software on a laptop that is currently running Abrites?
  9. #1718
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Hi. Maybe anyone can advice. Have fvdi v2015 that with softdog and internet sync from fly.
    Problem is that tag key tool not found.
    Gedding error that its not connected. Non of leds in on.
    Where could be problem?
    Photos
    https://imgur.com/a/i1Nox
  10. #1719
    Kocta's Avatar
    Mar 2017
    Audi A6 component protection 2gen. DSP basic - OK
    Audi A3 Dash RB8 -OK disconnect the battery min. 5 minutes
    Škoda Fabia dash- key - OK
  11. #1720
    Stelaras26's Avatar
    Nov 2017
    Skyrim
    you should try opening the tag key tool and check connections,or resolder the pins.
  12. #1721
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Done. Problem persists
  13. #1722
    Sep 2013
    Opel Vectra 2004 engine type Siemens simtec 22 SE petrol can't read pin from ecu or panel cluster .Sombody ty it ?.Do caprog work with this?
  14. #1723
    Sep 2013
    or Delphi sorry.
  15. #1724
    Dec 2017
    hello does anyone know if i can programm key for audi a4 2009 BCM2 module with fly fvdi 2015 ? make a extra key or all key lost situation.
  16. #1725
    Stelaras26's Avatar
    Nov 2017
    Skyrim
    Quote Originally Posted by drugowaz View Post
    If you try any tag key antenna from any fvdi device it should work..
    I have 2,if you are in Eu maybe i can help you.!
    FLY FVDI 2015 with time limitation??
    License expired,device has been deactivated.!
    Did anyone had same problem?
