Page 117 of 182 FirstFirst ... 1767107112113114115116117118119120121122127167 ... LastLast
Results 1,741 to 1,755 of 2730
  1. #1741
    Quote Originally Posted by zolee33 View Post
    Hi all!
    I have an FVDI with very irritating problem. Cannot connect to any VAG convenience module over Kline.
    -1C0 959 799 F
    -1J0 959 799 AH
    -6Q0 959 433
    in car&on table same result, it says: Unit not responding...
    What do i need to do?
    After replacing the L9637D and ADG1406BRUZ and K6 MOS relay will work?
    Someone has experience with this "bug" ? (sry my english)
    Attachment 440154Attachment 440155Attachment 440157
    Somehow resolved?
  2. #1742
    Jun 2013
    I have a clon 2014. Vectra c 2003 z20net no Read pin Code. Have anyone this problem?
    Wysłane z mojego SM-G390F przy użyciu Tapatalka
  3. #1743
    Jan 2013
    Quote Originally Posted by wbart View Post
    Wich version of software you use try with old version work fine
  4. #1744
    Jan 2018
    Jemen
    I would like to buy FVDI Clone. Which version to choose? 2014 or 2015?
  5. #1745
    Jun 2013
    Quote Originally Posted by fytfh View Post
    2014
  6. The Following 2 Users Say Thank You to wbart For This Useful Post:
    Col19 (10th January, 2021), oliva (14th February, 2018)
  7. #1746
    Sep 2012
    Cuba
    I need to add a new key using FVDI2 to a VW Gol 1.0 with the following data
    Address 01: Engine
    Part No: 030 906 034 T
    Component: MARELLI 4BV MPSF 1261
    Address 17: Instruments
    Part No: 5X0 920 827
    Component: 22-KOMBIINSTR. M73 V01
    I can not find any way to read the box (K-Line) to get the PIN-CODE.
    Any suggestions
    Thank you so much
  8. #1747
    Sep 2012
    Cuba
    In a 2014 Audi A4 B8 and 2014 Audi A6 to add a second key with a key that works properly with the car. It is mandatory to read the BCM2 through a programmer (Orange5) or it is possible to do everything using only the FVDI2 without the help of a programmer external?
    Audi A4
    Hardware part number: 8K0907064FQ
    Hardware version number: H11
    Software version number: 0621
    Designation of the system: BCM2 2.0
  9. #1748
    Sep 2012
    Cuba
    Maybe this question is silly but I prefer to be cautious.
    The black cable that comes with the FVDI2 adapter is for connecting an external 12V power supply. Whenever an ECU (MED17, etc) is to be read, it is necessary to feed this cable with an external 12V source
    Attached image of the cable.
    Thank you
  10. The Following User Says Thank You to eltoke For This Useful Post:
  11. #1749
    Sep 2012
    Cuba
    I wanted to thank this forum and especially this thread that gives us the possibility to clarify many of our doubts with this tool.
    Greetings from a country where there is no Avdi, FVDI, dealers and very little internet, where you try not to make mistakes because if you make a mistake you stayed without car.
  12. #1750
    Sep 2012
    Cuba
    Quote Originally Posted by totoo View Post
    FVDI 2 Update online(2017-2-16) Special Function
    Engine Control Unit: Detail can be found in chapter 6.1 engine control unit
    K-Line Instrument/Immobox: Detail can be found in chapter 6.2 K-Line instrument/immobox
    Change KM: Detail can be found in chapter 6.3 change KM
    Adapt Unit: Detail can be found in chapter 6.4 adapt unit
    Component protection: Detail can be found in chapter 6.5 component protection
    EEPROM dump Tool: Detail can be found in chapter 6.6 EEPROM dump tool
    As I see in this post there is a manual for the FVDI2, where can you get this manual?
    One of the things that most work has given me is to find information on how to proceed in each case and as published here there is a manual or a guide.
    Example
  13. #1751
    Feb 2016
    Can FVDI clone read write eeprom flash Volvo v70 2003?
  14. #1752
    Dec 2010
    Anyone help with key learning on Porsche 9x6 returning 'Learning Failed' - can run the key learning program successfully and see the current keys written to each slot but not write a new key without the 'learning failed' error. Do I need to write the alarm eeprom with the modified dump under the option 'enable access to alarm module by OBDII'? Not sure this should be necessary as PIWIS can do it without. Or can anyone tell me how to write a key to the binary dump directly? Thanks in advance for any help!
  15. #1753
    Feb 2018
    Spain
    Some of the function are working but some of them not
  16. #1754
    Apr 2014
    Any word on Range Rover?
    Sent from my SM-G930F using Tapatalk
  17. #1755
    Jan 2016
    i have fvdi clone 2014 , I get error message when I start up fvdi "file corrupted this program has been manipulated and maybe it's infected by a virus or cracked"
    if I reinstall software all is OK, but later again same error, can someone help me please ?
    Need I to disconnect internet ?
    dont have antivirus, use XP pro , no other soft are installed on laptop,,I use it just for FVDI
