Hello anyone tried to virginise a W211 cluster to input a new vin using FVDI ABRITES?
On a 2014 version, with VW 8.6, whenever I start the Micronas CDC32xx, I get "CDC32xx...cannot start programmer" error about 90% of the time. Even when it loads and I open a file, all other options a grayed out so I can get no information about the file. Any known solutions for this problem?
The repackaged version of FVDI2015 without VMProtect in Chinese bootloaders and run-time add-ons. Immo Plus for VAG is integrated into a Quick Loader. Nothing new, just more comfort
P.S. Link updated.
Last edited by miltas; 7th May, 2018 at 08:05 AM. Reason: Updated to V1.3. Fully works :-)
@miltas
Please reup, link is gone !
@miltas, can that one be used with a 2014 box?
Key learning Dodge Patriot 2010
fvdi
read skim ok
read pin ok
learning spare key with remote - ok
Key learning successfully...
Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
lion0304 (26th April, 2018)
I have FVDI 2015 which I'd like to use on a Mini Countryman R60 with CAS3+. I'd like to add a key, one key is still available. I suspect that CAS has been replaced since manufacturing date is 2006 and manufacturer part number is 6112233, while the car is manufactured in 2013.
CAS software is 9389116.
When I click CAS keys, normally FVDI would allow me to downgrade CAS, but on this car it gives the error "Error when disabling CAS security! Remove the ignition and try again."
Can I downgrade with WinKFP as well? If so which ZB-nr do I need to flash?
I am especially carefull since ELV is not programmed in this car.
Or is there another way to use FVDI 2015 to add a key to CAS3+?
I do have the WinKFP file for 9389116 and I can probably find the older files as well.
if you want to make bmw keys with fvdi you will end crying.....
figani (26th April, 2018)
I have used FVDI on CAS3 cars, but I don't plan to make a habit out of it - when possible I always buy dealer keys. However this car has 2006 CAS (according to the UIF) while it's a 2013 car, so I don't want to spend € 200,- on a key that will probably not work. I will get some help from a friend that owns an AVDI.
I'm not so scared of a bad flash in general. I've had some interrupted flashes and until now I always was able to recover via OBD using WinKFP in emergency mode or ISTA/P. I never had a bootloader flash fail on me though.
Hi been awhile been on here .so please excuse if say anything wrong. I after immobilized code program a existing key it on Clio 3 o6 plate vin number vf1br1a0h35432795 many thank in advance michael
