Page 132 of 183 FirstFirst ... 3282122127128129130131132133134135136137142182 ... LastLast
Results 1,966 to 1,980 of 2733
  1. #1966
    Talleresmalaga's Avatar
    Nov 2017
    Espaņa
    Kia Rio 2015, error add another new key and now does not start with any, no response from the immobilizer
    regards
  2. The Following User Says Thank You to Talleresmalaga For This Useful Post:
    HeXeN (4th November, 2018)
  3. #1967
    jurebv's Avatar
    Dec 2017
    Croatia
    Astra J 2012 , new body control unit, i read pin, change VIN and tried to key learning but once stored ones are deleted and try to program new i get message that limit is exceeded
  4. #1968
    doctore's Avatar
    Nov 2015
    Colorado Denver
    Quote Originally Posted by jurebv View Post
    reset battery and re-learning key again
    Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
  5. #1969
    jurebv's Avatar
    Dec 2017
    Croatia
    Same thing
  6. #1970
    Member zicopsg's Avatar
    Dec 2015
    Hello friends, can anyone tell me if fvdi 2015 does bcm2 audi a4, bcm does not recognize key, ..
    IF HELPED THANKS AND PLEASE REPUTATION
  7. #1971
    Kocta's Avatar
    Mar 2017
    Garage in the Czech Republic
    No. Ori Avdi,Vvdi.
    Press Thanks and Reputation
  8. #1972
    Feb 2013
    Dublin
    Hi Guys,
    Did any one try to use FVDI 2018 on Ford Transit 2007, I need to program key.
  9. #1973
    Feb 2013
    UK Bristol
    FVDI 2018 doesnt wont run IMMOPLUS 13.6..... is error 5
    Configured settings.ini and wroted correct source to ImmoPlus V13.6.exe
    used Loader and drag file ImmoPlus V13.6.exe to dialog ImmoPlis LOADER,,,, it is Error5
    Found on the youtube solution when problem was with FVDI drivers, but after 2h attempts, still doesnt`t want run ImmoPlus
    Tried to Windows 7 32 and 64it, Windows 10 64bit, and Xp 32bit.
    Someone know what is wrong, and know good solution for Run this
  10. #1974
    Oct 2018
    Europe
    im looking for a 2014 version? I believe this is the most stable version of this but only thing coming up in searches online is 2018 versions, anyone know where to buy one from, reliable source, thanks in advance,
  11. #1975
    Quote Originally Posted by Brof View Post
    im looking for a 2014 version of this but only thing coming up in searches online is 2018 versions, anyone know where to buy one from, reliable source, thanks in advance,
    fvdiobd .....
  12. The Following 2 Users Say Thank You to paul_12345 For This Useful Post:
    Blood58870 (6th January, 2019), Brof (11th November, 2018)
  13. #1976
    Oct 2018
    Europe
    Quote Originally Posted by paul_12345 View Post
    fvdiobd .....
    checked the site only 2015 on it
  14. #1977
    newone's Avatar
    Oct 2016
    http://www.fvdiobd.com/fvdi-abrites-...activated.html
  15. #1978
    Oct 2018
    Europe
    Thanks, think I need eye test, 🙄
  16. #1979
    Jul 2017
    hello, what you soler, mine not working too, so can you axplain
    Quote Originally Posted by doctore View Post
    after good soldering anthena, fvdi 2018 work
    tested for the purpose add key from eprom cas2-cas3+ with isn , write key dump saved unlock both oem key
    also will tested this days on car can duet or not
    Attachment 563482Attachment 563483Attachment 563484Attachment 563485Attachment 563484Attachment 563484
  17. #1980
    Mar 2018
    I have a 2011 BMW that has a CAS3+(ISTAP). I am looking to add a key to it myself. Can FVDI 2018 do the job? I need to update one of the slots in the CAS
