Page 102 of 183 FirstFirst ... 25292979899100101102103104105106107112152 ... LastLast
Results 1,516 to 1,530 of 2733
  1. #1516
    koolstuff's Avatar
    Nov 2015
    Dakar (Senegal)
    i purchase FVDI for PSA & Renault and yet i am still have issue to do calibration or pin code reading!!!!!!!
  2. #1517
    doctore's Avatar
    Nov 2015
    Colorado Denver
    Does anyone know which version fly fvdi can learning the spare card on reanult megana 3 and laguna 3 from 2009
    it would mean a lot to me
    Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
  3. The Following User Says Thank You to doctore For This Useful Post:
    mikajna (15th April, 2017)
  4. #1518
    lion0304's Avatar
    Oct 2014
    Quote Originally Posted by doctore View Post
    No one can answer because no any Fvdi can do that. Only tool i heard is Renault Ecu Tool but is very hard to find. Till looking for it with correct price.
  5. The Following User Says Thank You to lion0304 For This Useful Post:
    doctore (9th April, 2017)
  6. #1519
    Oct 2010
    Yeah i am trying to flash a sgo file to my car, on the first try when i get the flash status, it tells me that the preconditions are ok, but it fails with that it can not enter bootmode,
    on the second try it tells me this message:
    Preconditions:
    Error: Immobilizer is active
    VAG number from file: 1K0907115
    SW number from file: 0070
    Number of blocks: 5
    Block N 0 - compressed size 0x059C98 bytes, uncompressed size: 0x060000
    Block N 1 - compressed size 0x0F5F50 bytes, uncompressed size: 0x120000
    Block N 2 - compressed size 0x0000F4 bytes, uncompressed size: 0x010000
    Block N 3 - compressed size 0x01B190 bytes, uncompressed size: 0x020000
    Block N 4 - compressed size 0x019034 bytes, uncompressed size: 0x030000
    Entering bootloader... Failed
    Failed to flash device
    Do i have to deactivate the immobilizer with PIN?
    or is my Dongle broken?(How to check Dongle)
    I am Connected via OBD, Dongle with USB + 2x USB for FVDI...
    Kind Regards
  7. #1520
    Nov 2016
    Default ***** FVDI Technical Support *****
    Hello all members please help me
    I bought FVDI 2014
    Not worked the Toyot@ Transp0nder t00l.
    ANY SOLUTION
    Please help
    Enviado desde mi iPhone utilizando Tapatalk
  8. #1521
    mybe many time answered, but where can i buy a good FVDI commander? fvdiobd.com is a good one? thx
  9. #1522
    lion0304's Avatar
    Oct 2014
    Quote Originally Posted by yeager View Post
    Yes, my FVDI 2014 came from them and work OK.
    Version 2016 price came down again, now under 370$.
    You can buy and report for this version 2016 here.
  10. #1523
    I compare description on many sites, v2014 and v2016 have same sw versions ...
  11. #1524
    DashProg's Avatar
    Jan 2013
    Here
    Quote Originally Posted by koolstuff View Post
    It works only on valeo bsi and siemens regarding jhonnson control it's a killer don't try it on jc bsi
    Everything will be back in order - All my respects to DK's members.
  12. #1525
    Aug 2008
    Quote Originally Posted by DashProg View Post
    and you obviously dont read forums
    there is not a problem with johnson bsi if you do it the way you should and if you took the time to read posts on this you would have found the answer is just make sure there is a charger connected to car your working on or use another running engine with jump leads to car working on
  13. The Following 2 Users Say Thank You to tango For This Useful Post:
    doctore (20th April, 2017), Siham (20th April, 2017)
  14. #1526
    Siham's Avatar
    Jul 2014
    Or read it on bench ,connection diagram is available here on DK.
    BR
    No thank , no HELP .
  15. The Following 2 Users Say Thank You to Siham For This Useful Post:
    maybach_ (28th April, 2017), tango (20th April, 2017)
  16. #1527
    newone's Avatar
    Oct 2016
    Quote Originally Posted by tango View Post
    how much time does it take to read pin?
  17. #1528
    lion0304's Avatar
    Oct 2014
    Quote Originally Posted by newone View Post
    Less than a dammaged BSI by reading over OBD.
  18. The Following User Says Thank You to lion0304 For This Useful Post:
    Gavra (1st May, 2017)
  19. #1529
    Moderator
    PremierD's Avatar
    Jun 2009
    Latest news apparently ..
    VAG BCM2 ALL KEYS LOST FOR AUDI A6/A7/A8/TOUAREG from 2009 to NOWcan do 2017
  20. The Following 2 Users Say Thank You to PremierD For This Useful Post:
    doctore (28th April, 2017), mikajna (19th May, 2017)
  21. #1530
    doctore's Avatar
    Nov 2015
    Colorado Denver
    Key learning Dodge Caliber 2009
    Fvdi 2014
    Read Skim - ok
    Read pin - ok
    Learning Spare Key - ok
    Key learning successfully
  22. The Following User Says Thank You to doctore For This Useful Post:
    autotechmx (24th March, 2019)
