find manual
find manual
bcm2 elv adapt online offline -echange immodata -clone immodata sinchro bcm elv medc17 edc17 Crafter EZS e EDC17 sinchro -DPF/ EGR/ DTC/ removal/: IMMO ADAPT edc16 EDC17 edc17c64 C74 NOW WORKING MED17/MEV17/ VAG ecu clone full working all
PCR2.1 FULL CLONE ou adapt, clone all edc17 me17 , etc / dash echange immodata repair immodata add key etc etc
Please need help, have 2 NEC from ESL, after clear fatal error can't write or personalize, TP cleared box is ticket, can't clear tp or renew, even by OBD. Those NEC are damage?Anyway to recover it? thanks
Good evening everyone. I have a EIS A 164 545 18 08. Tried to calculate erase pass numerous times, but in vain.
Special Key: FDA87E918251033D
Would appreciate if somebody calculated an erase pass for me.
TY in advance
Hi, Does anyone have info about china BE key stopped working in a week or so after programming on w204? Is it a programming issue or a circuit board fault?
Does it work when you read it on VVDI. How about if you reprogram it?
labusas (29th May, 2017)
I never had this problem. Only heard of other people having problem with changing gears but not with starting the car.
Labusas did you check the key if it reads OK in the VVDI tool?
It can be the hash calculation or the key.
But it is most likely bad chinese key.
autoTkey (30th May, 2017)
Hi.
Please help . I need renew ECU me9.7.
Special Key: AF4EC7852809E818
I need ERASE PASS . ????
Thanks.
giovani (30th May, 2017)
How you get the erase pass? Vvdi not get it?
Enviado desde mi SM-G955F mediante Tapatalk
