auto techniek (21st November, 2017)
i dont know but for my the best is vvdi prog i doit all motorolla
yes i to same doit km read cas3 cas3+ cas4 cas4+
all mercedes and i verry happy all time all the work 100%
dont have any problem for 9s12
same time dont read 908 in wire but for this i have orange5 orginal
i to same go to custumer to make spare or lost key but i have in van sodering station.
and it is max 30min job and car start
Q E D . That is the point.
There is nothing safe for 5m48h, and mb ezs.
vageric (19th November, 2017)
You are wrong. But I will leave the conversation, as I do not have vvdi mb.
Let-it be.
ok bye ...
Thanks Kev
Mate , you do not want to read the manual ???
Auto reflash: Program will auto re-flash server result until there’s no task for this device. You can start data acquisition once more while auto reflash starting . Stop acquisite after success: If you are run data acquisition while auto reflash running, program will stop the acquisition progress when find correct password ............
drugowaz (20th November, 2017)
HI
Can you help me in an erase pass 7g tronic, sever not find erase pass.
Special key 46B87B2652138AC8
VVDI MB TOOL latest software version V3.5.0 update
*** 2017-11-21
*** Require firmware V3.5.0
===== BENZ V3.5.0 =====
1. Attention: All user update device to firmware v3.5.0, software v3.5.0
2. Improve the success rate of erase password, the server will continue improve the database
3. New function: Menu->Other Function->Eeprom dump tool, support repair W210/W220 ISN eeprom dump
4. New function: Menu->Other Function->Read/Write EERPOM via OBDII, support read CPU eeprom from W202,W208,W210 EIS directly with KLine
5. New function: Menu->Other Function->Customer request, support communicate unit with CAN command(Professional user use)
6. Support detect EIS CPU chip from OBDII, after read EIS data via OBDII, you can get CPU chip is motorola or NEC
7. Support renew W639, W906(NEC) ESL via KLine
8. Bugfix for OBD communication with W639, W906 on the bench
9. Bugfix for erase problem in W204 ESL
10. Bugfix for IR read key hash on the motorola EIS
11. Support W209, W211 read password(from IR) under OBD mode
12. Add W251 EIS type
13. In Prepare Key File window, support save the key file in EIS folder automatically
14. Support Polish language
15. Bugfix
Notes: please keep using latest software version, any problem post here or PM me.
alexxxb0450 (21st November, 2017), auto techniek (21st November, 2017), autoTkey (21st November, 2017), CaioW (21st November, 2017), CarCity (21st November, 2017), daxxer (21st November, 2017), Diablotic (21st November, 2017), grzyb26 (21st November, 2017), habbyb (21st November, 2017), jacostanzo (21st November, 2017), keyantic (22nd November, 2017), kostas (21st November, 2017), M3L3R (21st November, 2017), raints (21st November, 2017), rola1971 (21st November, 2017), solitaire (21st November, 2017), TeL200 (23rd November, 2017), vasiliev7719 (21st November, 2017)
Hello everyone , all updates are welcome .
Testing v3.5. making key w204, I have to repeat data acquisition
Enviado desde mi SM-G955F mediante Tapatalk
Same prob
