Page 324 of 450 FirstFirst ... 224274314319320321322323324325326327328329334374424 ... LastLast
Results 4,846 to 4,860 of 6745
  1. #4846
    auto techniek's Avatar
    Mar 2017
    When the eis is dead, does remote controle of the key supposed tot work or not?
  2. #4847
    rola1971's Avatar
    Jun 2014
    Dublin
    Quote Originally Posted by lush29 View Post
    On table or on the car?
    Sent from my SM-G950F using Tapatalk
    in table the best all job
  3. The Following User Says Thank You to rola1971 For This Useful Post:
    lush29 (14th May, 2018)
  4. #4848
    rola1971's Avatar
    Jun 2014
    Dublin
    Quote Originally Posted by minomino View Post
    Hello
    I need two token to calculate urgent data acquisition.
    my id: MB01862892
    with payment.
    Thank you
    or that someone can calculate me password
    you need buy tokens
    onlyone option
  5. #4849
    Jan 2013
    vvdi 2 not possible to read xhorse elv simulator this is some bug or is normal write data sucessful but read not possible
  6. #4850
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    Quote Originally Posted by fytfh View Post
    for what you need to read it ?
    when work, then dont waste time with them
    btw...VVDI2 sure can't read it success
    many thanks to friend kevfield
  7. The Following User Says Thank You to daxxer For This Useful Post:
    fytfh (17th May, 2018)
  8. #4851
    Jan 2013
    Quote Originally Posted by daxxer View Post
    sorry vvdi mb car is not here but think we will work if not work on test eis status we will see mech status ok but can status not ok i think but i see all ok
  9. #4852
    May 2013
    New VVDI keys are giving problem. They don't activate on EIS. Have tried about 3 or 4 vehicles and same problem. SAMIC said problem is in VVDI BGA Software. One key had activated on W202 EIS but after about 7 or 10 starts it failed and no response.
    I think there is still some bugs on these VVDI keys which need to be fixed up. I have the newer boards as I have sent SAMIC also pictures. They are 2018 boards and not the older boards.....
  10. The Following User Says Thank You to obeids For This Useful Post:
    PierreTheron (26th May, 2018)
  11. #4853
    Dec 2010
    if eis dead remote dont work
  12. The Following User Says Thank You to bluesky2010 For This Useful Post:
    auto techniek (22nd May, 2018)
  13. #4854
    Member Alexuko's Avatar
    Aug 2012
    Tenerife
    Good morning, people. Buy vvdi mb tool over a year ago !!! And I'm trying to load token and you can not. Device is not activated !! Bought in Xhorsetool. Quen, apart from them can you activate it?
    If I help you, please press THANKS button.
  14. #4855
    Dec 2016
    Hey ,members please l need to aske about w204 .c280 7 gear box programing by vvdi. we change used gearbox on car .car started fine but gear not change it. vvdi it show to how to renew gear box so after renew gear box .it not need to programing on car?.it will coding it self?.please can explain here .thanks on advance.
  15. #4856
    Basti13's Avatar
    UK
    Hello people , i need help , how can i renew delphi crd3.60 in w176 220 d from 2014 by vvdi mb tool ??? If yes how i can connect on bench ??
    NO PASS
  16. #4857
    lush29's Avatar
    Oct 2015
    Quote Originally Posted by Basti13 View Post
    Never did crd3 my self.
    But I ordered the adaptors and I did and crd2 and worked perfect.
  17. The Following User Says Thank You to lush29 For This Useful Post:
    Faraday (22nd May, 2018)
  18. #4858
    Basti13's Avatar
    UK
    I need this adaptors (ordered allready ) ? or can i have connecting diagram ?
    NO PASS
  19. The Following User Says Thank You to Basti13 For This Useful Post:
    iamfooser (22nd May, 2018)
  20. #4859
    Jun 2013
    Quote Originally Posted by Alexuko View Post
    I hope you have downloaded the latest software.
    And also I guess you need to check, if there is need of a firmware upgrade.
    After this it should connect to server, and activate for the next 31 days.
  21. #4860
    rola1971's Avatar
    Jun 2014
    Dublin
    check this manual may be help for you
    good luck
    http://noimmo.lt/Magic_Eraser_connection.pdf
  22. The Following 2 Users Say Thank You to rola1971 For This Useful Post:
    Basti13 (23rd May, 2018), rokibar (23rd May, 2018)
