Yeah but if I buy the BE key and use the points for a token ,which I did, and I don’t get my “free” token then I can’t do the job. What’s the point in spending money on tokens when I’m due one each day?
I shouldn’t have to buy more because chores didn’t fulfill their end of my purchase agreement.
At least with my MBE tool I got what I was promised when i purchased it.
Solved! all ok
By the way - about those Bonus Points from the Xhorse BE keys: how and for what can they be used?
I tried once to extract points from a Xhorse BE key but software said there are none in the key and didn't try since then.
Hi there
I have the following situaution...
Client has W204. When we read Original EIS then it shows half of the DATA. The SID matches the KEY but EIS show Not Activated and some of the data doesn't show.
So we have now these items: Original EIS, Original KEY, Original ESL, Donor (Used EIS from junkyard).
If I read data from key and ESL then would we be able to reprogram his original EIS or not?
If we use the Donor EIS then what are the procedure? Would we need to renew the ECU as well or not?
Could someone share a sim4le pin out.
I ordered the ECU renew cable set, but can not wait for IT to arrive.
Is there a gateway needed?
Your Pin out
I surprise those who do not want to use the Thanks and Reputation buttons but ask for the password of the files.
rob h (19th August, 2018)
Hi, Mates
Would you be able to help and get the erase password for EIS for W208, please?
Here's the datra:
key passw: DA9452A83C8BA742
Special key: F1724F01375CD0E0
Here is you Erase Password:
Jonny
labusas (22nd August, 2018)
